Hi, while I believe that most of the K-3 menu items are clear to me, there are few points (and one button) where I'm not quite sure...
C1 4. AE-L aretation with AF
C1 5. AE linked with AF
C1 6. Auto EV compensation
C2 10. WB adjustable range
What should I set, in which situation could this settings be useful?
Speaking about 4. and 5., what is the relation between these settings and the AE-L button? (which I don't really use, as I actually don't understand the function of this button very much)
Probably I have to mention that my mostly used settings are:
1) "normal" mode: AF.S, "Select" focusing area (central spot selected as default), multi-segment AE metering. Usually I focus in the center, lock focus by the AF button, then recompose and push the shutter release button.
2) "user 1" mode: AF.C, "Expanded Area AF (S) 9 points, multi-segment AE metering. C3 16. + 18 settings changed to "3".
I also set the Program line to MTF (my lenses are DA). Should I keep this setting or rather change it to different program line?
Thanks in advance for your hints...
