10-10-2014, 07:58 AM   #1
New K-3 sometimes won't autofocus on start up.
Hello all, my new K-3 won't autofocus sometimes on start up. The workaround seems to be to flip the af - manual switch, but that seems strange. It will take pictures - just no focus. The only lens I have used so far is my DA* 16-50, which works wonderfully on my K-5.
10-10-2014, 10:05 AM   #2
It may be the 16-50 communicating with the K-3.
Question - Do you have the camera in AF-S, AF-C, or AF-A mode?
I too have a 16-50 and K-3. The lens works great on my K10, K-01, and Kx, but not on the K-3. It will not focus sometimes, or it will hunt, but never lock on, and in anything but AF-C, will not fire. My guess is either the lens is decentered to a point, or the K-3's firmware is not compatible with the version of my 16-50 (one of the first years, and never had an SMC fail issue).
I don't have an issue with any other lens. Also, it seems to be gone, or reduced in LV mode.
I have a feeling I will need to send the setup into CRIS to get everything fixed, just have tried to determine if it is something else before I call Support.....
10-10-2014, 10:05 AM   #3
Happened to me...
But i thought it was my imagination. But it did this a few times. I tried a different lens and that was OK and changed back to my 16-50 and it was OK. Maybe it was a contact issue and it needed cleaning by just removing the lens.
Tim
10-10-2014, 11:42 AM   #4
Otis Memorial Pentaxian
QuoteOriginally posted by Daedbird Quote
CRIS no longer provides warranty service for Pentax cameras. Pentax support would be the first line of contact.
The comments regarding lens/camera communication are pertinent here. Clean the mount contacts (camera and lens) and see if it improves things.
10-10-2014, 01:21 PM   #5
I'll try to clean the mount contacts. I'll also try a different lens tonight. The camera doesn't even try to autofocus - it just shoots a picture. very strange...
10-10-2014, 02:12 PM   #6
QuoteOriginally posted by miltona580 Quote
AF-S and this won't happen.
10-11-2014, 11:53 AM   #7
My new K-3 appeared to work fine when I got it two days ago but now I can't autofocus with any screwdriven lenses. It appears to work fine with my SDM lenses. I did update the firmware from 1.00 to 1.11 yesterday, and I'm not sure if that's the last time it worked with screwdriven focus or not. Any ideas?
10-11-2014, 12:01 PM   #8
QuoteOriginally posted by gtcal Quote
Welcome to the Pentax Forums!
Conventional wisdom is to suggest you clean the lens mount contacts on both lens and body. If that fails, your best resource is the dealer from which you bought the camera to arrange an exchange.
10-11-2014, 07:41 PM   #9
Thanks for the advice, I tried cleaning the contacts, setting all the settings back to factory defaults, focusing in live view, af-s, af-c, different lenses. Absolutely no focus motor action, I guess I'll have to exchange it. It's unfortunate since I bought it from B&H Photo I guess I'll just have to wait until they reopen in a week or so.
10-14-2014, 06:18 AM   #10
The problem seems to be with the DA* 16-50. Other lenses don't have that issue.
autofocus, dslr, k-3, k3, pentax k-3
K-5 Autofocus switch won't turn to M setting EssJayEff Pentax K-5 7 09-03-2014 10:06 AM
16-50mm lens won't autofocus on k30, but will with other bodies Immunogirl Pentax SLR Lens Discussion 2 04-20-2014 10:20 PM
K-5 won't autofocus with remote Eistean Troubleshooting and Beginner Help 6 02-13-2014 03:48 PM
New k-500 won't shoot on occasion ... tbinder Troubleshooting and Beginner Help 2 01-04-2014 07:08 AM
Lenses that won't autofocus on the K-01 Designosophy Pentax K-01 28 03-17-2013 08:41 AM
All times are GMT -7. The time now is 10:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
