Originally posted by Tjompen1968 tells me that I will use the camera in rain and bad weather and if it fails they WILL fix it under warranty.
Funny...it does not tell me that. What it tells me is that they exposed a camera to light rain for less than 2 minutes. What is inferred is that it still worked afterward. I don't remember anything, inferred or explicit, regarding warranty if water is found in the camera.
What the owners manual (U.S. English version) says:
From the camera care section:
"Avoid contact with garbage, mud, sand, dust, water, toxic gases, or salt. These could cause the camera to breakdown. Wipe the camera to dry off any rain or water drops."
and from the warranty section:
"...Service will be rendered, and defective parts will be replaced without cost to you within that period, provided the camera does not show evidence of impact, sand or liquid damage, mishandling, tampering, battery or chemical corrosion, operation contrary to operating instructions, or modification by an unauthorized repair shop..."
It may be that the Swedish (where you are) or British (where the video originated) version reads differently.
