11-04-2014, 07:56 PM   #1
ISO and Aperture value in Video Mode
Hello,
I'd like to know if there is any way to retrieve ISO, Aperture and perhaps shutter speed settings from a video file?
I know it sound strange but I'm trying to compare some clips and want to know which settings were selected on the best ones...
I should add that the files are on the PC, no longer on the camera. I installed an app called MediaInfo that provides this info
General
Complete name : D:\My documents\My Pictures\1-DIGICAM\2014\20141103\119_0311\K3_P9025.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 141 MiB
Duration : 53s 554ms
Overall bit rate : 22.0 Mbps
Encoded date : UTC 2014-11-03 22:01:10
Tagged date : UTC 2014-11-03 22:01:10
PXTH :
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 21.2 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.342
Stream size : 136 MiB (96%)
Language : English
Audio
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Codec ID : twos
Bit rate mode : Constant
Bit rate : 768 Kbps
Channel(s) : 1 channel
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 4.90 MiB (3%)
Language : English
Unfortunatelly not the settings I am looking for...
Thanks,
Marc
11-04-2014, 08:04 PM   #2
Download the free version of PIE
Download - Picmeta Systems
This is what is shows for the K-50 video file.
11-04-2014, 08:35 PM   #3
QuoteOriginally posted by Steve.Ledger Quote
Mmmmmm probably a setup problem but...I am not getting this info at all using this tool. I get this kind of info for DNG files, not mov...
11-04-2014, 08:58 PM   #4
This appears to be significantly different information than is extracted by MediaInfo. I suspect that MediaInfo actually analyzes the header section of the data and not just the exif. If would be good to have a tool that does both.
11-04-2014, 10:25 PM - 1 Like   #5
QuoteOriginally posted by mamethot Quote
Yeh, I downloaded a K-3 mov and it doesn't seem to show everything in PIE.
However, grab Exiftool and the ExiftoolGUI, then you will get data.
Exiftool ► ExifTool by Phil Harvey
GUI ► Latest ExiftoolGUI version 5.15
---------- Post added 11-05-14 at 03:31 PM ----------
That's only part of what PIE shows. I cropped the screenshot to just what you see in post#2.
11-10-2014, 04:54 PM   #6
You can have exiftool write out the metadata into a file... -w TXT or so, though you can pick the filename.
bit, codec, data, date, dslr, exiftool, format, id, info, k-3, k3, pentax k-3, pie, rate, settings, tool, video
ISO in video mode coboren3 Pentax K-3 4 05-11-2014 02:18 PM
Using K10 In Manual Mode Aperture And Shutter Settings Change Suddenly Racer X 69 Pentax DSLR Discussion 9 10-21-2013 12:16 PM
K10d: Manual ISO setting in Aperture Priorty Mode bkhphoto Pentax DSLR Discussion 10 09-20-2013 08:15 AM
For video, does auto-ISO work in M mode? jake14mw Pentax K-01 4 01-27-2013 10:13 PM
Video mode and manual shutter speed/ISO ? alamm001 Pentax K-01 10 12-12-2012 04:49 AM
All times are GMT -7. The time now is 07:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
