11-15-2014, 03:41 PM   #16
Rimfiredude's Avatar
QuoteOriginally posted by gaweidert Quote
We anxiously await your report. We have voted and it is your turn to take one for the team.
Sorry guys, just went nuts on ebay. Bought a 100D with 18-55 for my son as a starter and scored an F SMC 70-210, 2.8 28A, 200M and a 50 f2 Ricoh. Done for the month. Someone else has to be the goat.
11-15-2014, 03:45 PM   #17
The Vivitar is the same lens. Usual Samyang quality control iffiness though -- I exchanged mine three times before I got a copy I'm happy with. The current $199 deal is very good though. (Amazon and B&H)
11-15-2014, 03:45 PM   #18
QuoteOriginally posted by krazykat Quote
I did a week ago, and it's great! Now I just need a Samyang/Rokinon/Bower to compare it too...
I'm sure it's the same lens. It had a version 2 released in 2010, just like the Samyang did. It even has the same nomenclature on the barrel as the version 2 Samyang (ED AS IF UMC). It looks the same in every photo. And then there's this: "Vivitar Series 1 13mm f/2.8 (rebadged Samyang 14mm f/2.8, released in 2010)" Vivitar - Wikipedia, the free encyclopedia
Bottom line, it's a great lens and for that price you can't go wrong.
Let's see some pics from it.
11-15-2014, 08:03 PM   #19
MJSfoto1956's Avatar
I had the Nikon version and it was extremely sharp -- I would have that lens again but for the fact that I have the equally stunning Nikkor 14-24mm. As a side note, I have the Samyang/Rokinon 8mm and it too is quite sharp. As a test, I "fitted" it onto my K-3 and the images were razor sharp. I'm a big fan of Samyang/Rokinon. I don't think you can go wrong.
M
12-04-2014, 09:26 AM   #20
fewayne's Avatar
Rokinon 14: All right so far
I have read that at least one rental shop considers the Samyang/Rokinon/Bower a "semi-disposable" lens, in that they're put together with glue and plastic and won't really hold up to hard use. That said, they're sharp, they're fast, and for the price you can replace it now and then if you have to.
Mine just arrived -- haven't even had a chance to really test it yet -- and I plan to baby it as much as possible. For me a $300 lens is really expensive, I'm one of those guys who scours eBay for old manual glass.
In fact that's a big reason why I went Pentax in the first place.
rw
12-04-2014, 09:36 AM   #21
QuoteOriginally posted by fewayne Quote
Check for decentering -- look for "smeariness" or excessive aberration that only happens in one or two corners. As I said, I had to get three copies to get a really good one (at least for the crop sensor, who knows what I'll find on a full-frame)...
12-05-2014, 03:01 PM   #22
fewayne's Avatar
Well, at a quick look I think I'm doing OK. Nothing very quantitative, just taped a couple of sheets of newspaper to a cupboard door (at that, not a flat one) and blasted away.
Think the corners are doing OK, but don't really have much basis for comparison, either. I clipped out the corners and jammed 'em into one PS doc. No sharpening.
---------- Post added 12-05-14 at 16:52 ----------
Just did a slightly better test (flatter wall) with very similar results. Hard to do the same at infinity focus unless you're shooting something REALLY BIG. :-)
12-06-2014, 01:28 AM   #23
vrolok's Avatar
When I received my Samyang 14, it was so-so... Did some test and the results were not too sharp, though not that bad either. Took me a little time to find out that this is quite a common problem with this lens though luckily it has an easy fix. Indeed I did calibrate the focus at infinity (you just have to play with three little screws) and... Voila! My copy is now very, very sharp, even wide open. I did an extensive comparison test with my da 12 24 (which I did sell) and the Samyang was a lot sharper across the whole frame for each f stop. Only cons: pretty important distortion, moustache-like.
All considered, it is one of my preferred lenses.
PS. The fish eye 8mm is next on my list, I will buy it soon.
PPS. With the K3, centering the focus at infinity is very simple. This is because we can zoom-in in live view, so getting a precise focus is a piece of cake. With other cameras, I guess, better using a teleconverter.
14mm, comparison, corners, couple, cupboard, doc, dslr, f2.8, fe14m-p 14mm f2.8, k-3, k3, lens, pentax k-3, ps, rokinon, rokinon fe14m-p 14mm, sharpening, sheets
For Sale - Sold: Rokinon 14mm f2.8 Aspherical Super wide angle lens jpsassy1965 Sold Items 1 03-28-2014 12:00 PM
Rokinon 14mm F2.8 - $265.00 woden2 Pentax Price Watch 3 03-26-2014 09:03 PM
K30-Rokinon 14mm wide angle- itiswhatitis Pentax K-30 & K-50 13 01-18-2014 11:55 AM
Wanted - Acquired: Wide / Ultra Wide angle lens for my K-5 GWARmachine Sold Items 3 03-23-2013 12:03 AM
Budget Ultra-wide Samyang 2.8/14mm ED AS IF UMC ovim Pentax SLR Lens Discussion 22 10-29-2011 08:04 AM
All times are GMT -7. The time now is 02:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
