11-06-2014, 02:20 PM   #1
Setting custom bracket intervals
So I was reading this article todayThe Optimum Digital Exposure. Essentially, the writer says to set the following bracket: +1.3EV, +.6EV, and +2.0EV to get the optimum exposure to capture all scene data, then in post process choose the one with whites closest to 99% and adjust to bring your dark levels back down.
I want to try this out. Is there a way to set a custom exposure bracket to use those EV settings instead of 0,+,-?
11-06-2014, 02:24 PM   #2
LensBeginner's Avatar
QuoteOriginally posted by scotty707 Quote
You can try setting a global adjustment for EV, which is +0.7 if you're working in thirds of stops and then bracket -2, 0, +2, which will ultimately give you -1.3, +0.7, +2.7
It's not exactly what you're after, but at least on my camera (K-01) bracketing can only be symmetrical (+-1, +-1.3, +-1.7, +-2 etc.).
Advanced cameras have advanced bracketing capabilities, and can bracket more than 3 shots.
Don't know on the K-5II or the K-3, for instance.
11-06-2014, 02:27 PM   #3
skunktail's Avatar
I haven't tried this, so I don't really know if it will work.
Bracketing with 2/3 of a stop between exposures and
a +1-1/3 exposure compensation would give you the above.
it might be worth a try.
Good luck.
11-06-2014, 03:22 PM   #4
jatrax's Avatar
As noted above, set your intervals to what you want, then use exposure compensation to adjust so you get the exposures you want. That's what I do on my k-3, works fine. Until you forget you have exposure comp dialed up by two or three stops when you stop bracketing.
11-06-2014, 03:51 PM - 1 Like   #5
Tjompen1968's Avatar
I have deselected the memory for the exposure comp so that when you turn it off it goes back to zero.
11-06-2014, 04:34 PM   #6
jatrax's Avatar
QuoteOriginally posted by Tjompen1968 Quote
Duh..... Why didn't I think of that? Oh, probably because on the k-5 series I always used +2/3 EV. Don't use any on the k-3 so this will work now.
Thanks!
11-06-2014, 05:12 PM   #7
clackers's Avatar
Ooh, good tip.
There are a few cameras like my Nikon P7700 where it's a dial at the top that is forever getting moved when brushed against, taken out of a bag, etc ....
bracket, custom, dslr, exposure, k-3, k3, pentax k-3
Help! Most used/best Custom Image setting for K-3? Luuk Photographic Technique 4 08-16-2014 07:27 AM
Custom Image (setting - question) ? Michael Piziak Pentax DSLR Discussion 4 06-21-2014 01:47 PM
k-30 in camera custom image setting mtkang Digital Processing, Software, and Printing 5 05-03-2014 09:26 AM
Auto Bracket Intervals for KM/2000 Cactisboy Pentax DSLR Discussion 5 07-27-2009 04:08 PM
Setting custom white balance. Deni Pentax DSLR Discussion 8 07-15-2007 04:05 AM
All times are GMT -7. The time now is 06:39 PM. | See also: NikonForums.com, part of our network of photo forums!
