11-29-2014, 02:33 PM   #1
radeon7750's Avatar
K-3 and Sigma 50mm f1.4 EX HSM issue
Anyone else having issues with the Sigma lens mentioned in the thread title? Mine just refuses to lock in focus sometimes ( and it happens quite often). I press the button halfway, the subject is (almost) in focus but I don't hear the confirmation beep. If I keep the button halfway pressed I can hear a noise...the HSM motor of the lens produces a whir...but that;s all it does. If I press the AF button again it just refuses to focus, making the same strange quiet noise.... Sometimes it makes that little adjustment needed for the subject to be in perfect focus and I get the beep, but this only happens in less that half of the cases. And when it decides to lock in focus, it is very sharp.
I've tested in different situations, places, lighting conditions...it;s the same. The same behavior was on a K-5.
So...is anyone else having the same issue?
K-3 FW 1.11
None of the other lenses I've tested showed such behaviour.
11-29-2014, 04:51 PM   #2
I have not had any issues. Send it to Sigma and let them calibrate it. At the widest apertures my 50mm F/1.4 does struggle with accuracy, but it locks. My Sigma 85mm is my most accurate lens. Is your lens new or used? Sigma might need to update the firmware in the lens.
11-30-2014, 12:28 AM   #3
radeon7750's Avatar
QuoteOriginally posted by Winder Quote
Thank you for replying Winder. The lens is new.
11-30-2014, 12:41 AM   #4
QuoteOriginally posted by radeon7750 Quote
If it is brand new. Send it back for another copy. I have had my Sigma 50mm F/1.4 for 5 years now. It has been on my K-7, K-5 & now the K3. The AF has been faster than the DA* 55mm F/1.4 lenses that I have tried.
12-03-2014, 11:38 AM   #5
radeon7750's Avatar
It was a new lens but it wasn't mine. I had borrowed it from a friend so I had to give it back.
Today I've bought my own new Sigma 50mm f1.4 EX DG HSM lens and it locks in focus every time, without any issues.
12-03-2014, 12:50 PM - 1 Like   #6
Good. Its a great lens with really good bokeh.
12-07-2014, 03:56 PM   #7
Got the same problem with my sigma 24-70mm 2,8 EX. I found out, that when i push the lens upward, the lens contacts loose their connection to the camera and i got problems with the autofocus too.
12-08-2014, 11:52 PM   #8
I have seen a couple of older Sigma lenses lose contact when moved upwards. I found tightening the 3 screw on the lens's bayonet ring fixed the problem. Just nip them up don't overtighten them.
12-09-2014, 09:16 AM   #9
radeon7750's Avatar
out of the 4 lenses ( sigma 10-20 f3.5 ex hsm, sigma 50mm f1.4 ex hsm, tamron 17-50 f2.8, pentax 55-300) which I tested on 2 cameras (k3 and k5), only the 50mm f1/4 had issues. But then again, as I mentioned above, I bought my own 50mm f.4 and this one doesn't have the focus confirmation issue like the previous one (which was borrowed from a friend).
beep, button, dslr, focus, k-3, k-3 and sigma, k3, lens, pentax k-3, sigma, sigma 50mm f1.4, sigma 50mm f1.4 ex hsm, subject
Anothe uterly uneccessary comparison Pentax-F 50mm f1.4 and Sigma Ex dg 50mm f1.4 HSM Stavri Pentax SLR Lens Discussion 18 09-18-2014 12:53 PM
For Sale - Sold: Sigma 50mm F1.4 EX DG HSM (price reduced/now shipping worldwide) pop4 Sold Items 3 04-11-2014 04:11 AM
Sigma 50mm f1.4 EX DG HSM ? Cregar Pentax SLR Lens Discussion 16 10-23-2011 09:21 AM
Sigma 50mm f1.4 EX DG HSM ? Big G Pentax SLR Lens Discussion 25 05-22-2009 05:59 AM
All times are GMT -7. The time now is 11:12 AM. | See also: NikonForums.com, part of our network of photo forums!
