12-02-2014, 08:38 AM   #16
QuoteOriginally posted by nicoprod Quote
Where was the lens fogged up? Front glass?
Aye, as far as I could tell. Inside the front element. It dried out ok, eventually.
12-02-2014, 08:59 AM   #17
Otis Memorial Pentaxian
QuoteOriginally posted by kshapero Quote
Or do I get some advantage from the sealed body?
Yes.
I have no WR lenses and frequently shoot in inclement weather with my K-3. I take reasonable care to avoid soaking my kit and am also careful as to choice of lenses. I figure that lenses with built-in motors might be a poor choice to risk water damage with. Legacy manual focus lenses, OTOH, are usually fairly water resistant by design.
12-02-2014, 09:14 AM   #18
nicoprod's Avatar
QuoteOriginally posted by Wolfeye Quote
It's definitely not normal to have some condensation inside a WR lens, unless it built up before the lens was mounted.
12-02-2014, 09:46 AM   #19
The lens was never off the camera, but I suppose it could have been there before shooting.
12-02-2014, 09:48 AM   #20
mikeSF's Avatar
If I get caught in a shower with my K-3 and a non WR lens (31/1.8), am I screwed as if the K-3 wasn't a WR body? Or do I get some advantage from the sealed body?
officially - this is bad.
off the record - likely no problem whatsoever. I've gotten drenched in rain, thick fog, and ocean spray with my non WR lenses on the K5 and 645D and as long as i wipe the lens base before changing lenses, I rarely see any more than the slightest ingress of water at the mount, never anything for me to worry about. I have on occasion wrapped a bit of Glad Press n' Seal or Saran Wrap around the focus ring and mount of a non WR lens if i was intentionally taking it into rain, but really, you may be pleasantly surprised.
good luck!
PS - I was out storm chasing last night with K5 and Sigma 10-20 and it got rained on. I just lightly wiped with a micro fiber towel and put the gear in my bag. Gear is ready for the next outing.
12-02-2014, 09:50 AM   #21
csa
csa's Avatar
QuoteOriginally posted by abmj Quote
When I paired my K-5ii with a Sigma 17 - 70 mm f2.8-4 macro as a standard kit, I just tossed a couple of the OpTech rain sleeves in the bag, just in case. They weigh virtually nothing and take up very little room.
Amazon.com : OP/TECH USA Rainsleeve - 18-Inch (2-Pack) : Camera Cases : Camera & Photo
Yep! WR or not, I would always take this precaution!
12-02-2014, 10:36 AM   #22
dadipentak's Avatar
QuoteOriginally posted by AquaDome Quote
I wouldn't take the FA-31 out without a plastic bag in my pocket.
There you go. In general, I think plastic bags are the work of the devil but I always have one in my pocket if there's any chance of rain.
12-02-2014, 10:49 AM   #23
kkoether's Avatar
I've shot in drizzle and light rain many time with my K200D and non-WR lenses with no issues. I keep one of these it the bag for heavy rain.
http://www.amazon.com/Cover-Camera-Protector-Canon-Pentax/dp/B00448SNN0/ref=...ra+rain+sleeve
12-02-2014, 04:05 PM   #24
emalvick's Avatar
My K-5 never had any issues shooting with the Tamron 17-50 in the rain and around waterfalls in Iceland. As others stated, one should always take precautions to dry the camera off, let it dry when it gets wet, and so-forth.
I never change lenses when shooting in wet conditions. I use a rain jacket and umbrellas to keep things mostly dry, and I've had no issues. The K-3 hasn't had any issues despite my first thought that it had some issues in a drizzle. It turned out to be a faulty switch unrelated to rain, and the photos turned out awesome. With the K-3, I stuck with the 18-135 because I was trying to travel with a one lens kit.
12-03-2014, 09:58 AM   #25
QuoteOriginally posted by lawjie Quote
WR is weather resistance....not water proofed........
i wouldn't do it....
Per Pentax,WR is Water Resistance, not weather.
All Weather (AW) is dust n water resistance. The DA * family.
12-03-2014, 10:23 AM   #26
QuoteOriginally posted by danny09 Quote
Per Pentax, the K-3 is "weather resistant" as well as "water, fog, snow, sand, and dust resistant", WR lenses are also marketed as being "weather resistant" and "dust resistant". The Pentax lens brochure explicitly states that WR = "weather resistant".
12-17-2014, 07:56 PM   #27
kshapero's Avatar
Anybody buying into this:
58mm WR Protector AFC9D0
Categories:
Lens
Filter
Water & Oil repellent- repels water drops and is fingerprint resistant
Antistatic- filter prevents microscopic dust clinging to the surface
An ideal, colorless filter for regular use- it will not affect color reproduction
12-17-2014, 08:02 PM - 1 Like   #28
JinDesu's Avatar
If WR doesn't count for weather resistant, then my DA 20-40 WR has been pretty lucky to survive some walking around with me.
@KShapero, interesting that Sigma has a whole series of WR filters. They appear to only be protective of the front element, so I don't see much point to them (besides being used in conjunction with Canon/Nikon WR lenses that "require" a front filter). I don't think it has a seal on the threads so it probably would not be useful with a rain-sleeve.
12-18-2014, 05:55 AM   #29
6BQ5's Avatar
That's what the DA 18-135mm is for. It's well worth a few f-stops of light for some extra seals.
12-18-2014, 09:12 AM   #30
Categories:
Lens
Filter
It's so VERY BIG so it must be good.
body, dslr, k-3, k3, lens, pentax k-3, wr
I Am So... Screwed! New Canon 5d dubiousone Non-Pentax Cameras: Canon, Nikon, etc. 16 09-24-2014 04:51 AM
Can I use K30 and a WR / 43 limited lens in heavy rain? icy Pentax K-30 & K-50 17 11-28-2013 11:52 AM
New K-5 II, and a noise I am not familiar with bunjes Troubleshooting and Beginner Help 16 08-14-2013 01:26 PM
Please help, i am about to buy a k-30 and i need some advice (mabe a lot). carlosodze Pentax K-30 & K-50 15 05-20-2013 11:11 PM
I am a pro shooter and here is why I am so excited for my K-5 to get here tomorrow benisona Pentax K-5 102 10-31-2010 04:52 PM
All times are GMT -7. The time now is 02:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
