12-02-2014, 01:43 PM   #1
Mapleleaf-Mick's Avatar
User programs on K3
On the K3, you have 3 user options of the mode button (User 1, User2 and User3). I am correct in assuming that in fact you have 4 or more user settings? I am basing this assumption on the fact that you can set your preferences while in say ATV mode and then also have the ability to set preferences in the three user modes. The big question I have is that when I turn the mode button from user1 lets say to ATV, does the camera return to the original settings that I had in the camera when using ATV. If this is the case, would user settings under the other modes i.e. aperture priority, shutter priority etc. also be retained within the camera.
Thanks for reading my post.
Michael J.
12-02-2014, 01:52 PM   #2
audiobomber's Avatar
QuoteOriginally posted by Mapleleaf-Mick Quote
Michael J.
The settings in TAv mode will be as you left them when you return to TAv from User Mode.
12-02-2014, 01:52 PM   #3
The three user modes have their own settings memory. A fourth global set of settings applies to every other mode and those settings are shared between them (P, Av, Tv, M, etc)
12-03-2014, 02:11 PM   #4
So Adam am I correct in assumming that if I am in P mode with certain seetings, go to TAV mode and change the settings, go to Av mode and have different settings again, then go into User 1 set and save different settings then go into User2 etc. when I go back to Tav mode I will have the settings that I saved in Tav mode originally? If that is the case, does that mean I can set up individual settings for each of the modes as well as individual settings for each of the user modes?
12-03-2014, 03:21 PM   #5
Almost. You'd have the settings from Av mode since TAv/Av/the other regular modes share settings.
atv, button, camera, dslr, k-3, k3, mode, pentax k-3, preferences, priority, settings, user, user programs
K3 - User 1, User 2, User 3... hjoseph7 Pentax K-3 14 01-21-2015 02:57 PM
Autofocus on the K3 Spodeworld Pentax K-3 14 12-01-2014 12:04 PM
Pentax K3 new user Charlie Agostini Welcomes and Introductions 18 11-20-2014 07:18 AM
K3 user intro.Norbert Norbert Ploetz Welcomes and Introductions 8 08-04-2014 06:22 AM
Interesting perspective on welfare programs mikemike General Talk 19 08-29-2011 02:28 PM
All times are GMT -7. The time now is 05:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
