Closed Thread
12-04-2014, 02:34 AM   #1
Otis Memorial Pentaxian
RobG's Avatar
K3 doesn't report lenses in EXIF
Is there a setting I've missed somewhere which will cause the K3 to report the lens name in the EXIF data? My K5iis does it, but the K3 doesn't.
12-04-2014, 02:46 AM   #2
Whatever software you're using to view files most likely needs an update. If you'd like to test your camera's files, upload one straight out of the camera using our attachment system, and see if the lens ID is there in the EXIF dropdown
12-04-2014, 03:13 AM   #3
You can also drop your images onto EXIFtool to see what it is reporting.
Lightroom, DxO and other software seem to have little problem finding the lenses attached to my K-3
12-04-2014, 03:26 AM   #4
I don't have any problem with Lightroom identifying my lenses.
12-04-2014, 04:31 AM   #5
RobG's Avatar
OK, thanks everyone. I've used the shutter count check (a mere 217) to display the full EXIF data from a jpeg and the name of the Tamron lens is there. I'll see if I can get updates for the software I'm using.
12-04-2014, 09:44 AM   #6
narual's Avatar
QuoteOriginally posted by RobG Quote
Does it come across as "Sigma or Tamron Lens" or something like that? Something about third party lens makers reverse engineering specifications at some point made that a problem, though I think the software should be able to work around it.
12-04-2014, 10:07 AM - 3 Likes   #7
The lens information is there in the makernotes section of the exif, but it is stored as a numeric code that may or may not be understood and mapped to a meaningful name by your software. Here are a few bullet points:
  • If you want to confirm the code for your lens, Phil Harvey's Exiftool is free and is usually up-to-date with support for all but the most recently released cameras and lenses. Unfortunately, while powerful and comprehensive, it is a little opaque to many users who are not geeks.
  • Adobe support for Pentax cameras with newer lenses is spotty. Lightroom 5.6, for example, properly parses and stores the lens code in the catalog on import, but may not map it automatically to the appropriate lens profile nor display the lens name. Go figure. I don't know about other software vendors.
  • Only lenses that have a data pin (all K-mount AF lenses) will transmit a lens code. For others the lens is coded as "0 0" (non-conductive mount/no lens), "1 0" (conductive mount K or M series), or "2 0" (A contacts present, no data pin, A series).
  • For a full list of codes known to Exiftool (exhaustive, but not authoritative) see LINK.
More than you ever wanted to know, eh?
Here is a link to the Exiftool Web site: http://www.sno.phy.queensu.ca/~phil/exiftool/
12-04-2014, 02:47 PM   #8
RobG's Avatar
QuoteOriginally posted by narual Quote
The whole title of the Tamron 17-50 f2.8 is in there. I actually first noticed the issue with the combination of the DA*300 and the TC. The thing which surprises me is that the same software recognised the lenses with the K5iis, and the tags shouldn't have changed.
Here is a link to the Exiftool Web site: ExifTool by Phil Harvey
Thanks Steve! Very informative. I've upgraded to PSP 7 but I haven't had the chance to check whether it picks up the lens data from the EXIF; it's not very smart with EXIF data even in version 6. Hopefully I won't have to buy DxO 10 to get EXIF data. I can always install the Pentax software for browsing, but I've never found it very useful. I generally use Irfanview for previewing because it's very fast and lightweight but this is the first time it hasn't returned the EXIF data properly.
12-05-2014, 03:51 PM   #9
Stumpy's Avatar
I also use Phil Harvey's excellent Exiftool but I use it with the GUI listed on his website, ExifToolGUI, makes it a lot easier
12-05-2014, 04:39 PM   #10
RobG's Avatar
QuoteOriginally posted by Stumpy Quote
Thanks for the pointer!
12-05-2014, 09:32 PM   #11
Errrr.. PSP7 - are you sure?
PSP7 was released Sep, 2000. The very first Pentax DSLR was released in 2003. You're expecting way too much if you think PSP7 should show you all EXIF..
12-05-2014, 10:20 PM   #12
narual's Avatar
QuoteOriginally posted by Steve.Ledger Quote
I was thinking the same thing. Paint shop pro 7? Not sure what else psp could be even as a typo. Photoshop 7 is just as old.
---------- Post added 12-06-14 at 12:26 AM ----------
Oh! Apparently they got bought out by Corel and at some point Corel decided to use a screwed up naming scheme. If I'm reading it right, jasc sold out at version 12, which Corel renamed "X2" .. Then x3,4,5, etc.. And now version x7, which would have been version 17 by any logical progression.
I honestly didn't know that software even still existed.
12-05-2014, 11:54 PM   #13
It doesn't, it's been Corelized...
And yes, it does help if people can be accurate in what they post.
12-06-2014, 04:46 AM   #14
RobG's Avatar
And yes, it does help of people can be accurate in what they post.
Steve, I never asked for your input with respect to Paintshop Pro.
12-06-2014, 05:09 AM   #15
I don't need your permission to post, Rob. This is an internet forum, I am free to comment as much as you or anyone else. If you could at least be clearer about the software you are using, folks might better able to help you.
So, is it PSP 7 or PSP X7 you are using?
Closed Thread
corel, dslr, exif, k-3, k3, k3 doesn't report, pentax k-3, report, report lenses, version
Sigma 70-300mm f4-5.6 Macro DG Lens doesn't work on my Pentax k3 Tiago Visitors' Center 8 12-17-2014 12:43 PM
EXIF data won't display in DCU4 sholtzma Pentax K-5 & K-5 II 6 08-14-2014 10:45 AM
Bower 85mm f1.4 doesn't report focal length ChopperCharles Pentax SLR Lens Discussion 3 06-13-2013 05:09 PM
Why doesn't Pentax work with Voiglander and/or Samyang to make lenses? Vantage-Point Pentax SLR Lens Discussion 5 04-18-2013 05:16 PM
Pentax K-5 doesn't record serial number in EXIF? pentaxmz Pentax K-5 & K-5 II 8 03-16-2013 11:24 PM
All times are GMT -7. The time now is 10:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
