Originally posted by az1895 I believe its WR even more....but Im really scared to do with it as I do the K30.
I think a move up from a K5 to a K5II or even K30 would be adviseable......Im having remorse over my very recent K3 purchase.
---------- Post added 12-09-14 at 11:00 AM ----------
Exactly ! I DIDNT need a K3.....should have just bought a K5II or yet just another K30.
My K3 is my baby so to speak , and since I shoot old glass Im not getting all that it can be. If I really dunk it its done as with any of the others also.
For me the upgrade wasnt worth it from a perspective of mainly shooting JPG and having trouble dealing with proper processing of RAW to get the most of the K3......poor lightroom user (inexperienced)
Maybe I will get past that , but Im unsure of my new purchase with the higher resolution sensor and noise + the added settings over what Im used to.
If knowing what I do now and was the OP......I would get the K5II as an upgrade , or a K30 for a second body.
Im finding the K3 a bit intimidating and frustrating.[COLOR="Silver"]
I'm not sure I get all the intimidation and problems people have or are concerned with the K3.
File size and resolution: Resize the image (downsize) when you are ready to use it. Unless you are printing a poster or something quite large, you don't need a final image to be at 24 MP (assuming you keep the original safe somewhere). If you think of 300 ppi as an ideal standard for a print, then an 8 x 10 photo is around 7.2 MP.
Noise: K3 images are slightly noisier than K5 images. It's a result of the extra resolution. Resize the original image to the same resolution as a K5 image, and the images will seem almost identical in terms of noise. In reality, you'll be able to resize smaller per the previous item.
Post Processing: I'm finding my K3 images need less post-processing than any camera I've had before:
1. With no AA filter, my images are quite sharp to begin with. I don't really have to apply sharpening in LR, and when I do I can get away with more than I used to do to the finer resolution. In other words, I find that I don't need to finesse the numbers as much
2. NR is the same thing. I can apply NR because the lack of AA filter has my images pretty sharp, and I can use quite a bit of NR before images get soft. I also keep in mind that images tend to look noisier at 100% (pixel-peeping) and on screen than they do at final size and on print. In other words, I can use more noise reduction, but I don't need it that much.
3. The K-3 meters the scenes quite well. My need for exposure adjustments is quite minimal compared to my K-5. Most work is probably confined to the mid-levels (curves and shadows) and perhaps bringing back highlights.
The end result is that my processing in LR is probably about 25% of what I spent with my K-5.
Ultimately, I'm finding the K-3 much better than I expected, and all the concerns and internal confusion over whether I should get a K-5 or K-3 have gone away. Heck, even my flash photos are coming out almost perfect now with little struggle. The camera and flash finally seem to be on the same page. My K-5 was always a struggle for using a flash.
