So I finally got a K-3, after using low-end Pentax models for 7 years. I've been using a K-30 before this. I have two questions
I've been reading you'll need high quality lens to take advantage of the sensor. Does that mean IQ of an 18-55 kit lens (or any consumer grade lens for that matter) will be worse on a K-3 than on any current 16mp sensor, or just the same? It could take a while before I can afford the better Pentax lenses
I also have been using natural color mode all along, except for the first couple of months when I got into this hobby, which I only used green mode
. I have read that the color from the K-3 is 'different', I think cooler is the correct term? But my initial impression was that it lacked some pop as the previous models I used (also in natural mode). Can it be the higher dynamic range of the sensor, making the images more 'flat' than the previous 12-bit models? I'm comparing shots (not methodically though) taken with the 35 2.4 and 50 1.8 primes.
As a side note, those two lenses above have very good contrast on my K-30.
Overall I'm happy with the K-3, and the 18-135 lens that came with it
