12-11-2014, 06:43 AM   #16
There might be a much simpler way to do this through exposure bracketing that achieves 95% of what you're trying to do.
Use spot metering
The rest that follows is very simple to set up in the bracketing function
Set up a 5-shot bracket
Set the brackets to 1 EV increments
Use the exposure compensation button to move the brackets to the right so the least exposed bracket is right on the "0" mark (so all other shots are of increased exposure: 0, +1, +2, +3, +4)
Set exposure to the brightest area (recompose if necessary for focusing)
Press shutter button and let the camera take the five shots
side note: you can even set the brackets to 1.3 EV intervals as long as the lowest exposure is moved to -0.3, this still provides for five shots with the brightest at +5 EV instead of +4 EV.
12-15-2014, 07:27 AM   #17
QuoteOriginally posted by IchabodCrane Quote
Use spot metering
I'll give that a try. The Nikons exposure bracketing was limited to 3 exposures at 1+/-
af, button, camera, dslr, exposure, focus, image, k-3, k3, k3 spot, live, move, nikon, pentax k-3, release, shutter, spot, tripod
Pets why use spot metering, in 1000 words jimr-pdx Post Your Photos! 3 07-27-2018 08:01 AM
K3, K5II spot af screwdriver222 Pentax DSLR Discussion 2 09-14-2014 09:29 AM
What is spot metering -K5 RachelDutch Troubleshooting and Beginner Help 28 08-29-2014 11:31 AM
Does spot metering still work with third party lenses JoAus Troubleshooting and Beginner Help 5 04-07-2014 11:27 AM
Spot metering for negative film Jamey777 Film SLRs and Compact Film Cameras 27 02-19-2014 08:37 PM
All times are GMT -7. The time now is 01:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
