12-16-2014, 07:11 AM   #1
murviper's Avatar
problem w/ new lens
I have a new K-3 and recently purchased a used Sigma 24-70mm F2.8. My problem is when I attached it to the camera and set the aperture value to say F4.0 or any other value the camera lens aperture value flickers and reads F-- . The camera will take a picture but it is black.
Is there a problem with the lens.
12-16-2014, 07:20 AM   #2
baro-nite's Avatar
If you're setting the aperture by turning the aperture ring on the lens, you have to go into the camera menu and enable the "use aperture ring" setting. If the lens has the "A" setting on the aperture ring it is simplest to use that, then control aperture with the camera as usual.
12-16-2014, 08:25 AM   #3
TER-OR's Avatar
Is it this lens?
Sigma 24-70mm F2.8 EX DG Macro Lens Reviews - Sigma Lenses - Pentax Lens Review Database
As Baronite said, make sure the aperture ring is set to A so the camera can control it. Many of the older lenses can be used manually, which is nice. Sigma has a tiny lock nub, IIRC, which you'll need to depress to rotate the ring.
12-16-2014, 08:55 AM   #4
murviper's Avatar
QuoteOriginally posted by TER-OR Quote
Is it this lens?
Yes, that is the lens. I have depress the rotate ring . When I did this when first put on the lens, & the aperture did appear, but now it does not it flickers and shows F--.
12-16-2014, 09:01 AM   #5
TER-OR's Avatar
You have to tell the camera to allow manual lenses.
It sounds like your aperture ring is not at the "A" mark, and the camera does not know what to do.
https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/110658-u...x-dslrs-f.html
12-16-2014, 09:20 AM   #6
aleonx3's Avatar
I think it is an AF lens without aperture ring, correct? could be faulty contacts...
12-16-2014, 09:27 AM   #7
TER-OR's Avatar
Or just dirty contacts, if there's no manual aperture ring. A dampened paper towel will clean it easily enough.
12-16-2014, 09:40 AM   #8
murviper's Avatar
The lens does have an aperture ring, but now I do think the their is a problem with the contacts. Taking it back to Henry's to see what they can do.
12-16-2014, 10:47 AM   #9
Na Horuk's Avatar
-Camera Menu, in the back, you should Enable aperture ring if you haven't already.
-On the lens' aperture ring, there is an A setting. You probably have to push a button or lever to set it to A. This is the best setting, that lets you set the aperture on the camera body and allows Av, P, and all other modes.
-If the lens does not have A setting, make sure you are using M mode and a fixed ISO (not Auto ISO). You use green button to meter. All other modes will revert to Av mode, with continuous metering, but always shooting wide open. If there is no A setting, the camera cannot know what aperture is selected - but in some cases it can stop down the lens to meter and take photos with the aperture chosen on the aperture ring. With preset lenses, the aperture is completely divorced from camera and has to be moved by hand every time.
-Make sure the lens and camera contacts are clean and free of grime or particles
-Make sure the lens is properly mounted, it has to click into place. Sometimes its a right fit, especially with third party lenses.
12-16-2014, 11:06 AM   #10
Hogdriver's Avatar
As Ter-or mentioned...Try carefully cleaning your ring faces (contacts) between both your lens and camera.
Hope this works.
12-16-2014, 11:55 AM   #11
murviper's Avatar
The lens does have an aperture Ring, I have moved the ring all the way over to the A position. The ring does click into place.I have enabled the aperture ring.
When I used it for the first time it did start to work. I was able to shot in landscape but when I tried for portraiture mode it would blink and change the aperture to F-- and not work.
12-16-2014, 12:11 PM   #12
QuoteOriginally posted by murviper Quote
Try playing with the aperture ring while set in the "A" position. While locked in the "A" position there might still be a tiny amount of play causing it to go to F--- if the camera is moved. I had exact the same problem with a Tamron 28-75 2.8 but couldn't find any solutions on the Internet. I ended up using a lens band (or any rubber type band) to keep the "A" setting firmly in place and it worked like a charm. Before that, any slight movement, such as turning the camera to portrait mode, caused it to read F---. Of course this would also be a defect and should be addressed by the store, either a return or a decent discount.
12-16-2014, 03:44 PM   #13
murviper's Avatar
ended up taking the lens back to where I purchased it. Henry's is sending out to be repaired ( back in 6 to 8 weeks)
aperture, camera, dslr, k-3, k3, lens, pentax k-3, value
"Nervous Nellie" w/ new K-3 problem... or not? Kayaker-J Troubleshooting and Beginner Help 5 03-27-2014 05:22 PM
aperture problem w/ 400 mm lens xxDavexx Pentax SLR Lens Discussion 12 11-28-2010 11:25 AM
Aperture 3 new problem w/SL update rickconklin Digital Processing, Software, and Printing 2 06-19-2010 10:31 AM
PROBLEM: Genesis 400 strobe lights w/ K-7 not working w/ sync cable slappy76 Pentax DSLR Discussion 8 02-27-2010 04:32 PM
All times are GMT -7. The time now is 08:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
