01-07-2015, 11:13 AM   #1
Spodeworld's Avatar
AF.A vs AF.C
Has anyone experimented enough with these two focus modes to get a sense of their real-world differences and where one actually performs better than the other? I understand the theoretical differences, but wondering what experience is showing us. (For example, Nikon has the same two modes. I've found that that AF-C works well enough on the D7000 that I just leave it on that mode.)
01-07-2015, 11:56 AM   #2
UncleVanya's Avatar
Really three modes on the K50 at least does the K3 only have the two? I use AF.S almost all the time unless I plan to take photos of something moving - this is annoying and I ought to try AF.A to see if it works well enough for my needs.
01-07-2015, 12:07 PM   #3
Driline's Avatar
QuoteOriginally posted by Spodeworld Quote
Mr.photouniverse on youtube states that the AFA has problems and you may get blurry out of focus shots. He recommends AF-S. He also recommends that you Disable the AUTO feature on High ISO NR (noise reduction).
01-07-2015, 01:13 PM   #4
AF.A is mainly for beginners as far as I can see. If you understand how each mode works, you should be switching between AF-S and AF-C depending on the situation (and most of the time, it will call for AF-S). I wouldn't stay in AF-C unless you're shooting moving objects.
01-07-2015, 01:20 PM   #5
Spodeworld's Avatar
I understand. AF.C with back button focus would be the ideal way to go, assuming that continuous focus is quick and accurate. This way, unless you hold the AF-L button down, it would act like AF.S. And, if there is subject movement, holding the button down takes advantage of the refocusing capabilities (AF.C engaged). This approach requires that AF.C works really well. I do that on the D7000, and found it to be very workable.
01-07-2015, 03:59 PM   #6
Tjompen1968's Avatar
It took some getting used to, but now I use the back button focus with AF set to AF.C and SEL M all the time. I find it to work really good.
01-07-2015, 05:02 PM   #7
CypherOz's Avatar
Concur. I normally use AF.S and AF.C for my wildlife photography
01-07-2015, 10:25 PM   #8
UncleVanya's Avatar
QuoteOriginally posted by tjompen1968 Quote
it took some getting used to, but now i use the back button focus with af set to af.c and sel m all the time. I find it to work really good.
sel m?????
01-07-2015, 10:40 PM   #9
drypenn's Avatar
I also use back focusing. My only beef against it is that you always have to remember disabling it for CIF to work.
Also, I don't get the AF-C while using BF and I stick to AF-S. What am I missing? Can anybody enlighten me on this one?
01-08-2015, 04:04 AM   #10
sel m?????
Page 44 in the manual.
---------- Post added 01-08-15 at 12:06 PM ----------
QuoteOriginally posted by drypenn Quote
I do not understand "I don't get the AF-C while using BF" What is BF and what do you mean with don´t get AF-C?
01-08-2015, 10:47 AM   #11
UncleVanya's Avatar
I think BF is back button focus.
I think the point is that the person does not understand why people like this method.
01-08-2015, 10:57 AM   #12
Ok. Thanks for the translation.
01-08-2015, 01:18 PM   #13
Spodeworld's Avatar
Using AF.C and back button focus gives you the best of AF.S and AF.C (in theory). Hold and let go, it acts like AF.S (good for stationary object). Continue to hold and it acts like AF.C (good for moving object).
This assumes that AF.C is well implemented.
01-14-2015, 01:10 PM   #14
cbope's Avatar
I tried this on my K-5 and didn't find it to work particularly well, it seemed that my focus keeper rate went down immediately. I went back to AF.S and BBF which is fine for me since I rarely shoot moving objects.
01-14-2015, 01:54 PM   #15
ScooterMaxi Jim's Avatar
QuoteOriginally posted by Driline Quote
Mr. Photouniverse? Umm. Watched 15 seconds and he summed up the camera, by saying, "There isn't much to say. Its a K-5 tweak."
Well, if someone is that unknowing about the product, why would we value his recommended settings? Yes, AF.S for most situations is correct. While I agree that it is probably best to disable AUTO NR at any ISO setting if you're into making the adjustments on your own, some folks might want to save post-processing time if they find a NR setting to their liking. Not sure I'd single that out for recommendation when its a personal preference situation.
af-c, bf, dslr, k-3, k3, modes, pentax k-3
AF-S vs AF-C, Interesting Observation! lightbulb Pentax K-5 7 03-01-2012 07:35 PM
Af.c, Af.s, Af.a iammokster Troubleshooting and Beginner Help 7 02-08-2012 10:18 AM
Pentax K-x: focus confirmation in AF-S, AF-C, not AF-A manteiv Pentax DSLR Discussion 24 12-10-2010 07:25 PM
Current Pentax AF.C Vs AF leaders Torrentes Pentax DSLR Discussion 10 08-10-2010 03:33 PM
Pentax AF vs Canon AF vs Nikon AF (In low light contitions) karq Pentax DSLR Discussion 110 01-13-2009 04:49 AM
All times are GMT -7. The time now is 12:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
