01-19-2015, 10:10 AM   #16
LoneWolf's Avatar
QuoteOriginally posted by zmohie Quote
Hi folks it has been with me about 9 months..k3 is a fantastic tool. it exceds my skills. I have had many k mounts cameras/2 k5s2+k200+k01+k5+k3/ and many lenses so iam familiar with pentax cameras but as the title speak i still get some blured pics. i do with k3 what i used to do with the others cameras. i need some experiences to get the best output of the camera. some settings or techniques or any thing could help to control this power tool.
thanks.
Found this in the USA K3 Thread, which appears to emphasise some of the points made in previous entries in this thread.
https://www.pentaxforums.com/forums/172-pentax-k-3/282441-k3-concerns-resolved-completely.html
01-19-2015, 10:23 AM   #17
Here is a set of bullet points:
  • Higher resolution has higher potential for disappointing results when pixel peeping. For perspective, down-sample your image to 16Mpx and compare to your K-5 IIs.
  • Your K-3 does not make your good lenses bad. They will perform as well or better at 24 Mpx as at 16 Mpx.
  • Missed focus is missed focus
  • Camera motion is camera motion
I went directly from a K10D to the K-3, but was pre-warned regarding the demands that the sensor would make on my technique. As a result, I was very happy with my results from frame one. To be honest, all of this is nothing new. I used to shoot Technical Pan back in the film days and it was well-known that the film required extra attention to technique to extract the full benefit of the media.
Edit: I was not going to say anything about noise (opens huge can of worms), but thought it good to at least mention the value of giving attention to noise reduction in PP if shooting above ISO 800. A little effort with the computer will pay a huge dividend on the final result.
01-19-2015, 10:47 AM   #18
I found that my first images with my new k3 were not tack sharp until I turned off high ISO NR in the menu options. They are actually pretty good even if it's set to MED but if left on "auto" it is way too aggressive and results in blurry images. Incidentally.....MED NR doesn't eliminate much noise anyways so I elect to leave it off completely.
01-19-2015, 10:55 AM   #19
mee
ISO 3200 (as in the example image) might also eat into the sharpness a bit..
01-19-2015, 01:50 PM   #20
pete-tarmigan's Avatar
Thanks to all
here is one and when back to home Iwill share more
The foreground looks sharp (closest part of the shirt). The lens seems to be focussed on that area.
01-19-2015, 02:09 PM   #21
beachgardener's Avatar
31mm @ f2.8 1/80s ISO 3200 it appears to be, have a look at the hair top right of image, the focus seems to be somewhere between the ear and forehead, might be back focus.
01-19-2015, 04:35 PM   #22
Bruce Clark's Avatar
Very sound comments so far on this thread, which I hope the OP will absorb and learn from, I know I have learnt a lot from this forum. Yet I still manage to produce a great number of less than ideal images. One tendency I have and which is not mentioned here is that I sometimes focus on a point say the eyes and then something moves slightly. It could be me shifting body stance slightly, it could be the subject moving. (a common event with animals and small children) In any event the focal distance set by the camera is no longer valid at the instant the shutter is pressed. The effect will be more pronounced at wide open apertures with close subjects creating a very shallow depth of field..
Solutions, singly or in combination
1 Use tripod. Ungainly sometimes but eliminates camera motion.
2 Use flash.
3 Adjust exposure. Smaller aperture, faster shutter speed, higher ISO.
4 Take many shots in the hope that one will be spot on. (Sadly it is often the shot in perfect focus that has the child with his eyes closed.)
5 Take more photos.
01-19-2015, 05:04 PM   #23
default High ISO noise reduction on K-3
If you are getting images that are not as sharp as they should be for a 24 MP sensor, check out this review of the K-3:
It is noted here as well as in dprreview that the "default" noise reduction of the K-3 may be too aggressive. This would cause images that are not sharp.
01-19-2015, 05:06 PM   #24
QuoteOriginally posted by jayman_1975 Quote
This has not been my experience when shooting in RAW. In that case, there is some difference in detail retention, but it is negligible and barely visible in full resolution crop. I presented my results in this thread:
https://www.pentaxforums.com/forums/172-pentax-k-3/282200-k-3-high-iso-noise-...-pictures.html
01-19-2015, 05:09 PM   #25
QuoteOriginally posted by dfp771 Quote
Pentax K-3: REDEMPTION - YouTube
See my note above. There may be a difference for JPEG shooters, but for RAW, any improvement in detail from turning the NR off is damn hard to see. I did my comparison images down to ISO 800 (the cut-off point) and concluded that disabling resulted in no improvement in image quality overall.
01-19-2015, 05:12 PM   #26
QuoteOriginally posted by mee Quote
Ya think
01-19-2015, 05:17 PM   #27
BTW..."Auto" at ISO 1600 sets the NR to "weak" (lowest setting). I believe it is off entirely at ISO below 800.
01-19-2015, 09:05 PM   #28
I had great photos when I first got my camera, like wow this is freakin amazing detail, then they got soft. I realized it was a setting I had, so I turned it off. Noise reduction maybe? Had great pictures again, but now soft again. I think I am going to do a factory reset and then change a setting a week at a time and see if I can figure out the culprit. Its got to be a setting, since I got consistently great photos for a time period in different exposures, even with high iso I was impressed. I need to write everything down. I am sure I am making menu changes and then forgetting everything I do.
01-20-2015, 04:09 AM   #29
zmohie's Avatar
Lots of great information. Thanks to all of you friends. I will read every thread tow times and keep it in mind. I also will try some settings you have mentioned and share the result. Thanks again to the best pentax community.
---------- Post added 01-20-2015 at 04:45 AM ----------
Direct camera output..noise reduction off.
01-20-2015, 08:13 AM   #30
That doesn't look right. You have high ISO NR off? Or low shutter speed NR off?
cameras, dslr, iso nr, k-3, k3, nr, pentax k-3, pics, shutter, steve, thanks, tool
Nature Cant get enough of these Bighorns Victor101 Post Your Photos! 3 05-27-2013 08:45 AM
HELP! Pentax Me super filmd rewind crank came off, cant get it back on kawehna Pentax Film SLR Discussion 7 04-01-2013 03:54 PM
I cant seem to get the aperture working as it should MADDSNIPER Troubleshooting and Beginner Help 22 03-24-2013 04:03 AM
cant get pictures on computer COULDD Pentax K-5 12 08-28-2012 09:51 AM
cant get film to reset Dlt Visitors' Center 3 10-08-2011 08:33 AM
All times are GMT -7. The time now is 05:10 PM. | See also: NikonForums.com, part of our network of photo forums!
