01-24-2015, 01:55 PM   #16
Instead of using "Apply All" and upsetting all your other lenses just use live view zoomed with focus peaking if using a tripod. That will always ensure the sharpest focus directly on the sensor. If you want to use Catch in Focus I would suggest a good quality fast AF lens.
With hand held shots I quite often use an older Sigma 28-70 f2.8 in manual focus mode and use my eyes to determine sharp focus. Sometimes it is different to where the green hexagon indicator suggests so I ignore it but it is always sharp when eyeballing it even without a split screen viewfinder. That's how the old film cameras worked with great success. We rely on the camera automation just a little too much these days.
01-25-2015, 06:17 PM   #17
QuoteOriginally posted by jhmos Quote
Yes, thats right, "AF Fine Adjustment" "Apply All" does work for manual lenses and can be used via the green hexagon signal. In addition, its useful for Catch in Focus (as long as AF button customization is set to AF1). For my Samyang 85mm F1.4 lens, the available adjustment isn't quite enough though.
John.
OK....this is what I was wondering. Thanks
---------- Post added 01-26-15 at 09:22 AM ----------
QuoteOriginally posted by Flasher Quote
Actually....I have no other lenses to upset. For me setting a "Apply All" setting is no big deal. I shoot about 99% manual lenses so Im used to it. The confusion started to come about with Manual lenses and "AF Fine" adjustment setting. The apply all does work for manual lenses, But nothing can be pre-set. Just a mental note on each lens and an appropriate setting when switching lenses. It is a bit confusing but slowly coming together.
adjustment, af, correction, dslr, focus, hexagon, k-3, k3, lens, lens correction, lenses, pentax k-3, post
Better Beamer w/ Correction Gel Question joe.penn Flashes, Lighting, and Studio 11 05-20-2013 08:47 PM
question re: CA and camera correction Mushu Troubleshooting and Beginner Help 4 04-15-2013 06:32 AM
Lens correction question cbope Pentax SLR Lens Discussion 21 12-15-2011 01:45 PM
K7 lens correction / software question RogerrDalTx Digital Processing, Software, and Printing 6 10-09-2009 09:33 PM
K20D Focus correction question sabarrett Pentax DSLR Discussion 4 08-22-2008 12:38 PM
All times are GMT -7. The time now is 07:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
