01-24-2015, 01:39 PM   #1
bavd's Avatar
diffrence between focussing in lv and phase detect
When using focus adjust for a front focussing tamron lens, I stumbled acros the the fact that although I can perfectly correct the lens using focus adjust,
it only needs to be done when focussing via the view finder. ie when the camera is using phase detect .
If I use live view the camera and lens focus perfect .
Could anyone explain? I am aware that the 2 focusing systems differ but I was under the impression that front or back focussing was a lens/body maladjustment that should
exist no mater the focus system used?
Thx in advance.
01-24-2015, 01:42 PM   #2
Front and back focus only applies to viewfinder AF. Here's an explanation why:
Fixing Front and Back Focus - Causes of Front- and Back-Focus - In-Depth Articles
01-24-2015, 01:44 PM   #3
bavd's Avatar
Wow that is quick. Thank you!
01-24-2015, 03:31 PM   #4
aleonx3's Avatar
As far as I know, Live view focusing use contrast detect AF system (CDAF) which is different from PDAF using viewfinder. So, it is conceivable that you may have FF or BF issue using PDAF.
01-24-2015, 03:41 PM   #5
The viewfinder prism might need to be shimmed. If you're using a split prism, I'd put money on it. There are plenty of threads you can look up describing the issue and fix if this happens to be the case.
01-24-2015, 06:09 PM   #6
CDAF uses the imaging sensor to focus. There's no front- or back-focus issues because of that.
Phase detect (or manual focusing in the viewfinder) follows a different optical path and calibration can be off.
camera, dslr, focus, focus adjust, front, front focus, k-3, k3, lens, live view focusing, pentax k-3, phase, view
How can I check if my Tamron 17-50 is front-focussing/back-focussing and needs repair photoleet Pentax SLR Lens Discussion 6 03-31-2013 03:58 PM
Exposure values between LV and PDAF mode different? raider Pentax DSLR Discussion 6 10-07-2012 03:16 PM
Phase Detect AF Tracking Test Pheo Pentax K-30 & K-50 3 07-15-2012 12:58 AM
Super Takumar 50/F1.4 MF focussing accuracy test using LV dosdan Pentax SLR Lens Discussion 3 12-21-2011 02:03 AM
Phase detect auto focus inaccurate fignewt18 Pentax K-5 13 11-18-2010 11:48 PM
All times are GMT -7. The time now is 06:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
