The screen on the K3 is bigger and easier to view in sunlight. The XT1 has the advantage of the tilt screen which is very handy at times and would love to see this feature come to the next K3. The battery life on the XT1 is poor and it gets worse if using LV. You will be lucky to get 200 shots using LV.. If you turn of the camera between shots you can extend this number marginally.
AF on both cameras depends on the lens used. The early XF lenses i.e. 35mm and 60mm are slow compared to the new lenses. There AF speed has been improved with firmware updates but are still behind the newer lens e.g. 23, 56 ,50-140. The fastest focusing fuji lens is the new 50-140mm competing with other brands best offering. The Fuji allows you to control the size of the focus point, using it at its largest setting, with lens wide open or near to wide open will increase focus speed, but due to the narrow DOF you can find it focusing on something behind or infront of the intended target. Using the smaller focus points improves accuracy significantly but at the price of speed and hunting in some cases. As far as shooting moving people I can't really comment as I used the LV for still subjects i.e. landscapes and macro. With all that being said, I think the XT1 AF is in LV is generally faster than the K3 and having the tilt screen is a big plus.
XT1 is quieter but not significantly so, unless you use the electronic shutter then it is silent accept for lens noise. Note the electric shutter can't be used when shooting moving subjects as you get the rolling shutter effect you see in video, distorting your image. The shutter sound of the XT1 has a slightly duller sound to the K3. If you are in a church both would be heard. Lens noise, Fuji lenses are definitely quieter than pentax screw drive lenses. The older Fuji lenses are noisy too i.e. 35mm and 60mm.. The newer lenses make "noise" but you need to be standing right next to the camera to hear. In a church hall, it wouldn't be noticeable.. Also, be aware that Fuji OIS can be heard when enabled, this does annoy some users but again its not going to be heard unless you next to the camera in a relative quiet environment.
Outside of the basic exposure adjustments and basic drive modes (CH,CL, bracketing...etc) which are available as dials on the XT1, the rest of the time you will most likely be menu diving or if your lucky the setting might be available on the limits Q menu. I find the K3 Info. menu has many more useful settings that I would like to change compared to the Fuji Q menu. K3 has the user program modes attached to the mode dial , allowing you to avoid menu diving if you have setup preset modes. Fuji requires you to use the quirky Q menu which most users hate, myself included, requiring you to use a menu and scroll through to find your preset. The Fuji presets allow you to save minimal settings too. Even with its larger feature set, the K3 is easier to navigate and get to the function you want.
I was seduced by the dials and retro look. Initially I thought the dials and aperture ring would make shooting "simpler" but in reality all it did was move my aperture control to the lens (i.e left hand). Even though I normally shoot in Auto ISO, I do shoot a lot in manual, with the XT1, ISO changes require me to take the camera away from shooting position as the ISO dial is on the left and is locked. On the K3, i can change the ISO with camera to my eye using my right hand. One of the main reasons I like the K3 so much over Nikon and Canons is its interface being all on the right side. I like to keep the camera steady with my left and change settings with my right..
If your going to move away from Pentax, for LV shooting I would look at the GH4 as it has the full articulating screen and very good LV tracking from all reports.
Originally posted by chiane
I wanted to ask you about if you used LV and if you could compare the two. As I mentioned in my op, I end up using LV instead of a viewfinder for most of my shooting. If you had to shoot people moving, which cameras AF works best now?
Which camera is quieter in operation, from lens noise while focusing, to shutter sound?
Which of the two cameras would you say allowed the most access to functions without menu diving or excessive button pressing? Visually the Fuji looks like it would operate more like the lx100 and be more fun than your standard dslr, but I've never used a dslr with the K3's level of control, so the k3 may trump it?
My requirements are a little different I think than the normal dslr shooter, so I am really having a hard time translating pros and cons into how I would use each camera.
