02-14-2015, 07:45 PM   #1
Shooting in Manual Mode with Auto ISO
I saw a YouTube video about some DSLR cameras being able to photograph using manual mode but set the ISO on auto so that your shutter speed and aperture stay the same and your ISO changes with the light. Can this be done on the K-3?
Thanks,
BrianS.
02-14-2015, 07:51 PM - 1 Like   #2
tvdtvdtvd's Avatar
Yes. It's called TAv and it's a Pentax exclusive.
02-14-2015, 07:59 PM   #3
Thank you, I will check that out.
BrianS.
02-14-2015, 08:05 PM   #4
Its my favorite mode and a perfect staring place if you ever used manual film cameras.
02-14-2015, 08:10 PM   #5
aleonx3's Avatar
The only difference I think between TAv mode (Pentax) and Manual with auto-ISO (others) is that in TAv mode, EV compensation is taken into consideration in metering where manual is manual (at least in Pentax world)... I could be wrong....
02-15-2015, 05:36 AM   #6
A very useful setting. I use it when chasing butterflies using a 100mm macro. I know I have to be around f8 for the necessary dof, 1/500 is the minimum for shutter speed considering my shaky hands and the subject not sitting still. So I set those and let the camera determine the ISO, which is the one variable left. The only concern is too much light, which is solved by upping the shutter speed.
Btw other brands have it too, just not (always) as a separate program setting. On my Sony A7 I use it all the time. Set the program M and ISO to auto. Exposure compensation works too.
02-16-2015, 02:02 PM   #7
Otis Memorial Pentaxian
QuoteOriginally posted by aleonx3 Quote
...except that auto-ISO is not available in M mode on the K-3.
For other current Pentax APS-C bodies, I believe that M mode with auto-ISO is a pass-through default to TAv mode. At least that is how the K-50 manual reads.
02-16-2015, 02:35 PM   #8
aleonx3's Avatar
Steve, you are correct, the only Pentax camera that implements manual with auto-ISO is the k-01, which I also have. I think Nikon's implementation of manual+auto-ISO is similar to that in k-01.
auto, dslr, iso, k-3, k3, mode, pentax k-3
While shooting in manual mode with the EV meter all my photos are slightly too dark. Newtophotos Photographic Technique 8 10-16-2013 09:47 PM
Shooting in Auto vs Manual lokin4deer Pentax DSLR Discussion 30 09-11-2013 05:08 PM
Auto ISO in manual mode yusuf Pentax DSLR Discussion 37 03-10-2012 05:44 PM
Auto ISO in Av Mode v5planet Troubleshooting and Beginner Help 8 03-30-2011 09:46 AM
K10D. Bug with Auto ISO in P mode? Edvinas Pentax DSLR Discussion 21 12-30-2006 05:47 PM
All times are GMT -7. The time now is 12:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
