02-17-2015, 12:43 PM   #1
marmitse's Avatar
How to match strobe and ambient color temp using the K3?
I am doing a project where I shoot shopkeeper portraits in their stores. The idea is to catch a large part of the interiors in these photos and there are lots of different lights there. I want to use a fairly small aperture to get decent depth of field, so extra light is needed for fill.
I have three different strobes, gels and a few modifiers for the lighting. I know the basics to color match the flashes to the ambient: CTO gels for incandescent and green+CTO for fluorescent light but I would like to be a bit more prescise (without buying a dedicated color-meter) and now to my question:
How can I use the K3 manual whitebalance metering to actually find the right gel combination so that my flashes best matches the ambient color?
02-17-2015, 01:50 PM   #2
JeffB's Avatar
On the K-7 and K-5 there is no direct method. I take a custom white balance and a test shot using an expodisc (filling the frame with a gray card would work too) under each light source with each white balance. You can then look at the individual RGB curves of each test shot on the camera. This will let you see how much additional R, G or B is present under each light source. Add gels and take more test shot until you get the RGB curves balanced for the strobes using the white balance of the ambient lighting.
02-17-2015, 03:47 PM   #3
narual's Avatar
QuoteOriginally posted by marmitse Quote
Do you have an iPhone? You can get a Luxi for $30 - it's a little plastic dome that clips onto the front-facing camera of the phone and turns it into an incident light and color temperature meter. Or you can get a real dedicated incident light meter for a lot more money and a little bit better accuracy.
02-17-2015, 03:58 PM   #4
marmitse's Avatar
QuoteOriginally posted by narual Quote
Luxi seems like a low cost intro to Light metering. I am on Android and Extrasensory devices web says they launched an Android version which is great. However I can only find info on light metering - is it really also a color temperature meter?
02-17-2015, 04:17 PM   #5
narual's Avatar
See screenshot. This is using the LightMeter app, i don't have the luxi app installed since I already had this one.
It's also using a Kleenex instead of a luxi, since that's what I had handy.
It was pointing at a window showing an overcast early evening sky with dark steel grey walls and white trim, with about 350-500 watt equivalent in full spectrum CFL bulbs behind the phone. (Fighting seasonal depression with photography gear!)
---------- Post added 02-17-15 at 06:25 PM ----------
Oh, nice. They came out with a less stupid version. The original only worked on iPhones with no cases, which is dumb - it's just a piece of plastic that you stick on your front facing camera. Now they have one that clips on any device up to a half inch thick, so it will work with cases, tablets, android phones, etc. assuming there's an app that can make use of it anyway.
02-17-2015, 10:58 PM   #6
marmitse's Avatar
OK, so there is a color temperature reading, but thinking of this how would the smartphone trig on a flash? And a look at their FAQ says:
"Does Luxi work with flashes?
Unfortunately not. While Luxi itself has no limitations on this, light meter apps are unable to detect light coming from flashes due to smartphone / tablet hardware limitations."
02-17-2015, 11:54 PM   #7
narual's Avatar
Sorry, maybe I misunderstood. Why would you need it to trigger from the flash? You want to know the ambient light temperature, so you know what color to gel your flash with so it's a decent match for the overall ambient temperature, right? I suppose if it could capture flash you'd be able to verify you got it right, but since you're shooting digital, I'd expect a glance at the photo would tell you that.
Now, if we're talking exposure now rather than color, and you mean you'd want the flash detected to assist in choosing the correct balance of flash power and ambient, well, yeah, you're probably going to need to get a real light meter if you want a device that will do that for you. But you can probably figure it out without one
Strobist: Lighting 101: Balancing Flash and Ambient, Pt 1
02-18-2015, 12:40 AM   #8
marmitse's Avatar
Of course you are right, why over complicate things? The gel color temperature is marked on each gel and the Rouge kit I have also states temperatures for some gel combinations - that could actually work.
02-18-2015, 01:41 AM   #9
marmitse's Avatar
Hm, I downloaded the Luxi app for Android and there is no color temp reading, just the EV and Lux. But looking around in the Google Play store for color measuring apps I found this super simple app "Color Temp Meter" for just a dollar, working just with the Smartphone camera naked, without a Luxi dome. Probably not very accurate, but a first test with daylight, incandescent and fluorescent lightsources seems to be pretty OK.
The question is why can not my much more advanced K-3 camera do this?
02-18-2015, 02:16 AM   #10
K-3 and Manual White Balance (menu).
There is in K-3 menu a method for whitecard (or a piece of white stuff, whatever you call white, i.e. your bride).
Greycard should also work I guess.
I'd like to test that menu way with 'white cap', which may mean commercial white cap to be put on the lens, or just camera body white cap (is that truly white?).
You simply go to the White Balance -> Manual White Balance -> "1", "2" or "3", you aim at your white card/white stuff and press the shutter, then after you press "OK" you just programmed your "1", "2" or "3" manual white balance in the camera.
I guess you may experiment with Manual WB and your gels.
Did you check if K-3 Exif shows adjustment done by Auto WB mode?
Actually, what means Exif data WhitePoint (i.e.: 18528 8192 8192 12896), and could that data be helpful in any way?
The question is (or should be) wider:
What actually Manual WB means in terms of the colour curve shape?
The same question (concerning colour curve shape) is for K-3 Multi Auto WB menu function.
The curve shape is important for fluorescents (fluorescents have two-three or more 'colour peaks') or for mixed-source lights.
Let's say we mix low-temperature (i.e. incandescent / halogen bulb) light with high-temperature (ie. flash or true daylight) light-source on one picture.
How K-3 Multi AWB / AWB algorithms handle the above?
Does K-3 simply 'average' the colour temperature curve as to have just one 'peak', or they ingeniously create 'two peaks' colour curve to adjust your art?
02-18-2015, 04:07 AM   #11
narual's Avatar
Like I said, I didn't use the Luxi app for it, I had a different one. I think I paid a buck or three for it. Your phone works as a reflective light meter bare - you need a dome diffuser thing to do incident metering
Without some kind of diffuser like the dome, you're probably picking up one specific light source more than another, but hey, it's better than nothing I guess.
As for your K3 -- It's doing exactly the same thing your phone is doing when you're using it that way, and probably doing a better job of it. It's looking at the light that's reflected off the subject and its surroundings, assuming that the whole scene averages out to 18% grey, and most of the time, that's a pretty decent and usable thing.
What your K3 can't do is sit facing your K3 from across the room and tell you what the ambient light falling on the subjects is like, and get good results in places where it doesn't come out to 18% grey.
A snowy day with a bright blue sky - it'll meter to grey. A closeup of a bride in a white gown? grey. A closeup of a groom in a black tuxedo without much shirt exposed? Grey.
An incident meter tells you how much light is actually there, not a guess based on what it assumes the average scene should look like.
I doubt the luxe is as accurate at that than a real dedicated light meter, but it fits in your pocket a lot easier (and is a heck of a lot cheaper than a new one -- but you can get an old one for under $50 that'll still do a good job if you put the correct batteries in it)
Of course, it's probably a lot easier to just get it approximately right using EV adjustments in the camera and then tweak it in post.
02-18-2015, 04:43 AM   #12
marmitse's Avatar
Right, thanks narual for clarifications. I understand that the K-3 averages the reflected light into the sensor and that a dome would enable an incident light measurement (I guess there are domes also for DSLR lenses). Either way it would be nice to be able to have the color temperature reading (of reflected or incident light) in deg Kelvin directly in the camera, so that I can decide on the corresponding strobe gel. The best camera practice I have found for now is to make a test shot (of the reflected scene) and to manually set the white balance temperature (in WB menu K1, K2 or K3) so that the camera LCD picture resembles the scene I see with my eyes. In this way I get an estimated color temperature (I guess like Prakticant writes above), but there should be a more precise way I think.
And yes tweaking WB in post is OK, but problem arises if there are multiple light sources with different temperatures. Just trying to avoid that.
ambient, ambient color temp, android, app, color, cto, dslr, flashes, gel, k-3, k3, light, pentax k-3, strobe and ambient, strobes, version, wb, white balance
Lighting Color Temp Choice sumx4182 Flashes, Lighting, and Studio 10 04-03-2014 05:02 AM
How to meter ambient light exposure when a flash is mounted? skyer Flashes, Lighting, and Studio 19 04-24-2013 10:13 PM
how to control ambient vs flash light? HSV Flashes, Lighting, and Studio 26 12-23-2012 12:29 PM
How to match the colors in stereoscopic pictures turay Digital Processing, Software, and Printing 4 12-03-2010 09:35 AM
How to remove color in a background and match a style N.Stocks Digital Processing, Software, and Printing 8 05-23-2009 03:08 AM
All times are GMT -7. The time now is 11:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
