Show Printable Version 6 Likes Search this Thread
02-20-2015, 04:54 PM   #1
Trouble dialing in 1/180 directly on my K-3
Maybe I'm missing something but I am unable to directly dial in a 1/180 shutter speed on my K-3. I wanted to set that for shutter priority when I use flash so I don't go over the sync speed set by Pentax. I can get 1/160 but the next setting is 1/200. No 1/180. Is this something that just gets set when using flash and is not a general choice?
What I want to do is to make sure I don't go over the limit. Maybe there is another way to do this other that shutter priority. I'm still learning so be gentle.
Last edited by RodBoy; 02-20-2015 at 05:02 PM. Reason: More clarity as to what I want to do
02-20-2015, 05:03 PM - 1 Like   #2
Otis Memorial Pentaxian
Set your exposure increments to 1/3 stop 1/2 stop.
02-20-2015, 05:10 PM - 1 Like   #3
QuoteOriginally posted by RodBoy Quote
Hi RodBoy
In Custom menu 1
Change EV steps from 1/3 EV steps to 1/2 EV steps
That should fix it.
---------- Post added 21st Feb 2015 at 10:15 AM ----------
QuoteOriginally posted by DoubleD Quote
Hi RodBoy
In Custom menu 1
That should fix it.
To slow on the key board and then I come up with the opposite to Stevebrot said.
I have mine set ti 1/2 EV steps and I get 1/180 shutter speed, if I change it to 1/3 EV steps I end up with the same shutter speed that RodBoy gets
02-20-2015, 05:20 PM   #4
Thanks a lot DD. I did that and it pops right into 1/180. I hoped it would be something simple.
This should help others as well. I never see that mentioned in anywhere else.
That fixes my problem.
I would be nice to here what others do to keep from going over 1/180 in flash mode.
02-20-2015, 05:24 PM - 1 Like   #5
You can also use X mode. It sets the shutter speed and you can set the aperture and iso.
02-20-2015, 05:30 PM   #6
That's what I wanted to hear. Thanks derekkite .
Any downside to using "X" all the time for flash?
02-20-2015, 05:49 PM - 1 Like   #7
It is a manual mode; the p-ttl will adjust the flash for proper exposure so you have to know what you are doing. If you mount a flash in TAV mode, turn it on it will set the shutter speed to 1/180 and allow you to go lower. I found the iso too high in TAV mode when it is set to auto. None of the modes will allow the shutter speed to be higher than 1/180.
02-20-2015, 06:19 PM   #8
QuoteOriginally posted by derekkite Quote
I don't have pttl with my v850 cheetahlight so that's not a problem.
Thanks
02-20-2015, 08:16 PM - 1 Like   #9
Sorry about that, I have been fooling with settings and had it backward.
02-22-2015, 04:45 AM   #10
HSS (High Speed Syncro) mode.
Depends on your flash unit.
When using Pentax, Sigma, Metz flash pls set the flash to HSS (High Speed Syncro - set it on the flash itself, not in the camera body), then you may set whatever camera body shutter speed you want (with Pentax DA lenses).
You may leave HSS setting on the flash as permanent and choose slow speed sync / trailing curtain sync mode of your choice in the camera menu then.
02-23-2015, 03:58 AM   #11
Yep, if you want ambient light to have a bigger influence in the resulting picture.
02-23-2015, 04:50 AM   #12
Depending on the light, I often set the camera to "X Sync" and set my iso at 800 or even 1600 to allow for some ambient light to get in and then use bounce flash. The results are usually pretty good. If it is bright enough, you can turn down your iso.
The biggest mistake I see folks make with flash is not to have a high enough iso set. That will give the flashed person in a black environment effect.
02-23-2015, 02:46 PM   #13
ScooterMaxi Jim's Avatar
Do you have an optical slave you can put on the Cheetah? I use a Wein HS (mounts to flash shoe), and it works great if you set the on-board flash to M. The on-board can dial down to next to nothing (1/128), serving effectively as a Controller, or provide a small ratio as Master. Easy to balance the two flashes however is most pleasing. The camera won't allow you to set the shutter speed above 1/180th with the on-board flash raised, so you can retain the 1/3rd stop shutter preference - going from 1/160 (or anything lower) to 1/180 but not beyond. I get especially good, soft light results when using the Joe Demb deluxe pop-it on the on-board, and the LumiQuest 80/20 system on the larger flash.
02-23-2015, 06:02 PM   #14
I think I can do that with my transmitter for the cheetah. The flash has a receiver on the side that talks to the transmitter. The transmitter sits on the hotshoe.
---------- Post added 02-23-15 at 08:14 PM ----------
The cheetah will also trigger from the onboard flash so I can use that to trigger the cheetah and also get some additional light from the camera with a diffuser.
At least I think I can, haven't tried that yet.
02-24-2015, 08:50 AM   #15
Yeah, I didn't know if you had the transmitters. Nice to have, but I like to travel as light as possible, and worry about as few batteries as possible. And to state what's obvious, anything mounted on the hotshoe takes away the ability to use the on-board flash. So, yes, I would encourage you to play with your set-up sans transmitters. Remember, only M is completely dependable (single flash) because you introduce potential error with a pulse (pTTL preflash). Also, M is the only mode that gets you instant shutter release as the K-3 is particularly slow in pTTL. Its a shame so few users understand just how great it is to have M ratio on-board, freeing us from the pitfalls inherent in pTTL.
change, cheetah, custom, dslr, ev, flash, k-3, k3, menu, pentax k-3, priority, shutter, steps, transmitter
180 3-in-1 Focusing screen Verglace Pentax K-5 & K-5 II 3 09-20-2012 03:18 AM
People Dialing in My K7 jerryleejr Photo Critique 3 09-10-2011 09:51 PM
Any way to get to 1/180 in 1/3's? lavascript Pentax K-r 4 01-25-2011 06:31 PM
TOKINA RMC 1:3.5/70-210mm PENTAX K-mount F error on my K20d gybp Pentax SLR Lens Discussion 3 12-10-2009 12:02 PM
Dialing in focal length on K20 gamgee Pentax SLR Lens Discussion 10 04-10-2008 03:29 PM
All times are GMT -7. The time now is 03:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
