02-22-2015, 11:43 AM   #1
Batter Door Issue
I just received my K3 in the mail and spent a day testing. The first thing I noticed was the battery door doesn't sit flush when locked. The door is flush at the hinge but where the pin is inserted into the body is where I see a little bit of a lip and I can fit a finger nail in there.
Has anyone else experienced this issue. I believe it is a defect and I don't have confidence holding the camera in wet weather.
02-22-2015, 12:06 PM   #2
My K-3's battery door is essentially flush with the body. I would contact your dealer to exchange for a replacement camera.
02-22-2015, 02:05 PM   #3
Don't risk it. Return it!
02-22-2015, 03:26 PM   #4
Do you have the battery door closed properly? When closed, it should look like pic related:
QuoteOriginally posted by bassfishjosh Quote
A pic will help us visualize that. Do you mean the area circled in red here:
If you are worried about the weather sealing, follow the little rubber gasket that surrounds the inside of the battery door cover. You will notice it wraps around the outside of the part of the battery door cover that presses down on top of the battery, and when the battery door is closed, the battery cover gasket there seals the battery chamber. The area circled in red in the image above where the door hinge is (and where the little spring is) is unsealed, but that's OK. The hinge doesn't need to be sealed.
02-22-2015, 03:38 PM   #5
The metal piece inside of the door is operating properly. The hole where the metal piece slides into when twisting the knob was cut too high. Thanks folks, back in the box return with another on the way.
02-22-2015, 06:12 PM   #6
Cool!
Sending out-of-spec cameras back through the dealer is the best way to improve the breed. Those cameras make their way through the quality assurance process and help Ricoh find and correct worn-out or defective tooling.
03-03-2015, 12:59 PM   #7
OK, I just got my replacement in and there is a noticeable difference between the two doors. This one fits flush and has a suction feeling when opening. Very satisfied. Off to film the A380. Joy.
03-04-2015, 08:47 AM   #8
Cool
That is the kind of happy ending we all like to see.
03-10-2015, 02:51 PM   #9
AWESOME!
I would just like to add that other than an M series Leica, Pentax does the best battery doors in the business. It's one of those little things that just makes you smile every time you use it.
door, dslr, issue, k-3, k3, pentax k-3, pentax k3 defect
Architecture Door to door... Neville Post Your Photos! 8 02-12-2014 10:48 PM
Misc back door, front door - lorikeets & Rouletts Cee Cee Post Your Photos! 12 03-21-2013 10:55 PM
swing batter........... dcmsox2004 Post Your Photos! 4 08-30-2009 07:34 PM
Batter N Bruise cupic Post Your Photos! 3 08-02-2009 05:41 AM
Batter up! Play Ball! Falcons Post Your Photos! 5 10-25-2008 03:34 AM
All times are GMT -7. The time now is 03:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
