03-10-2015, 01:09 PM   #31
I have checked my K-3 in TAv-Mode. After pressing "AE-L" I can change the speed while the camera chooses the ISO accordingly (not the aperture). And I can also change the aperture while the camera chooses the ISO (not the speed). In my opinion that's what you want.
At the beginning you mentioned, that your are using firmware 1.0. I'm using firmware 1.11. May be, that's the problem, but also may be, I had changed some setting month ago and I don't remember.
03-11-2015, 02:08 AM   #32
QuoteOriginally posted by siegbert Quote
Steve already suggested this as well.
But there seems to be a problem with auto iso and flash. i never work with flash so i don't have a clue.
Would love to understand though...
03-11-2015, 02:25 AM   #33
Thanks a lot for that. Oh, I guess is the Firmware then. But I guess I still need to AE lock to avoid the ISO flying around during TAv mode. But anyway, is not that important. Just need to work my fingers more. Not an issue at all.
Cheers and have a nice day ya....
03-11-2015, 04:35 AM   #34
sterretje's Avatar
QuoteOriginally posted by grispie Quote
Read the camera manual It has a table with guide numbers at the different ISOs. But you probably skipped that part as you don't use flash
Guide number defines the power of the flash. With a simple flash (no (p)TTL or auto-thyristor, no power settings) correct exposure of a subject at a given distance is defined by guide number and aperture. The basic formula that reflects this is
subject distance = GN / aperture.
As guide number varies with ISO, one needs to change the aperture when ISO changes if the subject distance does not change. If one forgets this, result will be underexposed or overexposed flash shots.
The same formula applies to auto-thyristor and (p)TTL flashes; however the calculated distance is now the maximum subject distance. The flash (auto-thyristor)) or the camera ((p)TTL) determine correct exposure and the flash light will be switched of when the subject is correctly exposed. When a subject is closer than the maximum distance, it will still be correctly exposed. No issues with (p)TTL and auto-iso; auto-thyristor can have a problem if aperture and ISO on the flash don't match those on the camera.
On some auto-thyristor flashes (those that don't support (p)TTL) you have to set ISO and aperture to reflect the settings on the camera; forgetting this might again result overexposed or underexposed images. Others (that support (p)TTL as well) can take / get those settings from the camera and from that perspective act like (p)TTL flashes.
There is however also a (lesser known) minimum flash distance (roughly 10% if the maximum; use this as rule of thumb if documentation does not give a number); and that is where the problems comes is. Camera cranks up the ISO and then the minimum flash distance can easily become greater than the subject distance and result is overexposure.
Hope this explains it.
Note: subject distance is the distance from flash to subject without bounce; formula changes when using bounce.
03-12-2015, 12:30 AM   #35
QuoteOriginally posted by sterretje Quote
yes it does!
thks for that :-)
aperture, camera, cheers, d610, drop, dslr, exposure, iso, k-3, k3, light, m-mode, mode, pentax k-3, pm, post, question, question about k-3, shutter
Use of Pentax Series M Lens with K-5IIs & K-3 in manual mode nhlblues Troubleshooting and Beginner Help 4 01-17-2015 01:13 PM
K-3 manual flash mode jatrax Pentax K-3 11 07-21-2014 05:48 AM
Quick question about K-30 read noise and ISO-lessness Beetle B. Pentax K-30 & K-50 8 05-02-2014 05:03 PM
Beginner question about manual mode DSLRnoob Troubleshooting and Beginner Help 7 01-30-2010 05:03 PM
just a quick question little laker Site Suggestions and Help 5 09-12-2006 06:32 PM
All times are GMT -7. The time now is 06:23 PM. | See also: NikonForums.com, part of our network of photo forums!
