03-24-2015, 11:52 AM   #1
bobbotron's Avatar
PC cable for K3
I have a really basic question, I was hoping someone here could help me out. I have one of these cheap strobe flashes, I'd like to try hooking it up to my k3 via a PC sync cable. But I'm not sure what cable ends I need to do so, I'm getting confused by all the options online being new to the world of sync cables. Am I looking for a "Sub Mini to Male PC Sync Cord" type of cord?
Also, if I want to run a number of such flashes, am I best off to let one optically trigger the others, or run a sync cable splitter?
03-24-2015, 12:06 PM   #2
Good question. The product description is not helpful. The socket on your camera is a standard female PC fitting, so a standard male PC should work on that end. One of the reviews indicates that a cord is included. I would call B&H to confirm before ordering. As for corded vs slave usage...I believe that these are conventionally used as slaves unless the setup make it difficult to trigger using light.
03-24-2015, 12:15 PM   #3
You might also want to ask if they know the trigger voltage at the PC pin. While your K-3 is supposed to use a hardened circuit for PC sync, there is no sense testing the feature with anything more than about 30V.
03-24-2015, 12:36 PM   #4
bobbotron's Avatar
You know, that is a great question. I'm not 100% sure I'd trust their answer. I have a cheap radio trigger I should really be using for this, avoid the potential risk to the k-3 all together. :O
Edit - that said, I have asked on BH, hopefully their reply will help someone else with the same question. I have one of these units already, they're really fun to work with.
cable, dslr, flashes, k-3, k3, pc, pc cable, pentax k-3, sync
PC cable for K-3 BruceStrachan Troubleshooting and Beginner Help 7 12-11-2014 11:29 AM
PC for pp Another dyemention Digital Processing, Software, and Printing 5 07-21-2014 04:38 PM
K200D not able to connect to PC through USB cable ducdao Pentax DSLR Discussion 15 05-22-2011 11:53 AM
How get multiple PC connections using one PC jack? davidstone Pentax Camera and Field Accessories 3 10-01-2009 05:19 PM
Question PC - error / issue with Modern Skin. NOT SITE MY PC HELP!! vievetrick Site Suggestions and Help 2 11-06-2008 11:24 AM
All times are GMT -7. The time now is 04:26 AM. | See also: NikonForums.com, part of our network of photo forums!
