Originally posted by rmtschanz Off-topic a bit, but the K-3 will hunt less in low-light if you use the "AUTO" focus point mode, then press the "1<->2" button to shrink down the focus point size. When AUTO mode is shrunk down, it's moveable and larger than the center spot mode.
I see what you're saying. I never noticed that 1x in Auto is a bit larger than Selectable. The hunting is a little less (just as the K-01 with the much-larger selected area hunts less). Seems like the biggest difference between 1x in Auto and the Selectable is that you can move the selection around much faster (about 5x), but the precision of where you end up is far-less exacting. Depending on the shooting situation, those are good choices to have. For my style of shooting, I would tend to use Selectable, but I certainly can see where AUTO would come in very handy.
