04-03-2015, 07:36 AM   #1
Exposure Bracketing Problems
Hi
Ive just got myself a K3, (Ive been using 2 K5 bodies & Ive physically damaged both)
when I put it into Exposure Bracketing, how do I get it to keep the same aperture?
On my K5 bodies its simple & I can get only the shutter speed to change, but the K3 adjusts both aperture & shutter speed.
Im in Manual mode & trying it side by side with 1 of my K5's using the same settings.
04-03-2015, 07:49 AM   #2
jatrax's Avatar
Put it in Av mode.
It works the same on my k-5IIs. In M mode it changes both aperture and speed. In Av mode the aperture is locked.
Unless there is a setting to change this that I'm not aware of that is how it has always worked for me.
04-03-2015, 07:56 AM   #3
Put it in Av mode.
In Av mode, the meter will be changing exposures, I need to be in Manual. My K5 doesn't work this way.
04-03-2015, 08:02 AM   #4
jatrax's Avatar
QuoteOriginally posted by Biggzie Quote
Maybe I am confused what you are trying to do. Exposure bracketing does change the exposure, is that not the point?
If I put either camera in manual and use exposure bracketing both aperture and speed are changed. If I put either in Av then only speed is changed.
What is your ISO doing? Do you have the k-5 in auto ISO?
04-03-2015, 08:13 AM   #5
Otis Memorial Pentaxian
As I understand it, you are wanting to set an arbitrary aperture and shutter speed and have the camera bracket the shutter speed only. I have no idea how M mode bracketing works on the K-5 except for your description and to be honest, I find this behavior surprising About the best I can offer is to shoot in Av and use the EC and AE-L buttons to get the initial shutter speed you want.
04-03-2015, 08:20 AM   #6
Unregistered User
Guest
Why do you need to be in Manual? What is it you are trying to accomplish?
04-03-2015, 08:21 AM   #7
jatrax's Avatar
As I understand it, you are wanting to set an arbitrary aperture and shutter speed and have the camera bracket the shutter speed only. I have no idea how this works on the K-5 except for your description and to be honest, I find this behavior surprising
The only way I can think of is if the ISO is actually changing as speed and aperture remain fixed. But I honestly do not know how to make that happen. Have not tested bracketing in TAv or Sv might have to try and see what happens.
04-03-2015, 08:25 AM   #8
Yes that is the point, exposure is changing ... I have set the ISO, Aperture & shutter speed, then Ive asked the K3 to do a 5 shot bracket ... it is doing that, but I don't want the aperture or the metering to change.
With the both my K5 bodies in Manual, the Aperture stays constant & the speed changes. So I can set DOF & the camera handles the exposure.
With the K3, I set the exposure settings that I want, turn on Exp Bracketing & the 1st shot has less DOF than I want, & the last shots with more than I want.
---------- Post added 04-04-15 at 01:58 AM ----------
I find the K3 surprising. The Exp Bracketing on all the other bodies Ive owned since the film days has been the same.
---------- Post added 04-04-15 at 02:02 AM ----------
QuoteOriginally posted by Tjompen1968 Quote
Im trying to get bracketing in Manual without the camera re-metering the shot & without changing the DOF
---------- Post added 04-04-15 at 02:06 AM ----------
Exposure Bracketing has worked the same on my K10, k20, & both my K5 bodies ... I don't see whats changed with the K3
04-03-2015, 08:39 AM - 2 Likes   #9
You can set this in the menu. Go to menu item E-Dial Programming; in the 2nd tab there is a M line, where you can set the behaviour of green button to TvSHIFT.
Now the camera will only change shutter speed during brackets and when pressing green button in M-mode.
I had to do this on both my K-5 and K-3.
I hope this was what you were looking for.
04-03-2015, 08:40 AM   #10
Unregistered User
Guest
What I do is that I use Av, lock the exposure and bracket. That manual mode only should bracket the shutter is not logical. What if I want to only bracket the aperture while in Manual?
04-03-2015, 08:55 AM   #11
QuoteOriginally posted by smartinsen Quote
Excellent ... that worked ... Thank you
---------- Post added 04-04-15 at 02:29 AM ----------
That depends on how you look at it, I find it not logical for the camera to change DOF while bracketing & that's the way every body has worked up to this.
I also find it annoying I couldn't find it easy in the manual or searching for help online.
04-03-2015, 09:00 AM   #12
Unregistered User
Guest
Really not very logical but great to know. Thanks!
04-03-2015, 09:06 AM   #13
Thanks! That is the obvious answer! I forgot about this hidden side-affect of the e-dial programming and it quite nicely provides an explanation for the OP's K-5 behavior.
04-03-2015, 09:18 AM   #14
None of my film cameras does automatic bracketing, though my K10D worked the same as my K-3.
Your K-3 brackets from the initial reading and does not change between exposures even if the light changes.
I believe that the default setting for the green button in M mode on the K-5 is the program line. That is how it is on the K-3. I suspect that yours was moved to Tv shift at some point since that behavior makes good sense to many people who mostly use Av mode.
04-03-2015, 09:25 AM   #15
jatrax's Avatar
Agree. Now that I checked that is on my list of programming changes for new bodies. Had to do it on k-5, k-5IIS and k-3. Maybe that setting is used for green button stop down metering on M42 glass? Don't remember except that I always change it for some reason and I was not aware it changed the bracketing behavior.
aperture, av, bodies, bracket, button, camera, change, dof, dslr, exp, exposure, iso, k-3, k3, k3 exposure bracketing, k5, menu, pentax k-3, people, post, shot, shutter, steve
Exposure Bracketing gordon_l34 Pentax K-3 & K-3 II 3 06-08-2014 05:48 AM
HDR vs. Exposure bracketing regislea Troubleshooting and Beginner Help 10 05-06-2014 05:27 PM
K5 iis exposure bracketing timer chickenandavocado Pentax K-5 & K-5 II 14 09-18-2013 06:19 PM
Exposure Bracketing mayday295 Photographic Technique 4 05-18-2013 01:28 PM
HDR/Multi-exposure/Exposure Bracketing sany Troubleshooting and Beginner Help 4 04-24-2011 08:52 PM
All times are GMT -7. The time now is 12:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
