Originally posted by stevebrot Oh...I am sorry. I thought the mirror box was blamed as the cause for the bulk
FWIW, Here are some numbers. I added a Pentax MZ-6 into the mix since it has built-in winder (motor drive), PDAF, FF pentaprism, e-dials, and built-in flash.
Pentax Super Program
Size (W x H x D)
131 x 86.5 x 47.5 mm (
538246 mm^3)
490gm w/o film (battery weight is insignificant...button cells)
Pentax K-2S
Size (W x H x D)
122 x 91 x 72.5 mm (
804895 mm^3)
678gm w/battery
Pentax MZ-6
Size (W x H x D)
135.5 x 92 x 63 mm (
707112 mm^3)
400gm (!) w/o battery or film
Take away the SR and the rear LCD and the K-2S would be about the same size as the MZ-6. Add a real battery and film to the MZ-6 and the weight would be similar as well. So, it would appear that things are not as bloated as we might imagine.
Mind you, the MZ-6 is FF 35mm and that is where things get a little sticky, though I don't see why a FF dSLR should not be possible in a package not too much larger than a Sony A7II + Novoflex K-mount adapter.
