04-25-2015, 02:23 AM   #16
What we can use this feature for depends entirely on how long it takes to shoot. Any motion in between shots will cause artifacts on the final image. Unless pentax makes it blisteringly fast, it probably won't be useful for landscape photography.
04-25-2015, 03:23 AM   #17
QuoteOriginally posted by CNunez Quote
I think what Jonby said is correct. You take a high res shot and also a normal shot and then if there are areas where there are artifacts, it is fairly simple to blend the images. I don't think it would be as hard to use as some think. HDR combines multiple exposures as well and while I wouldn't use it on a very windy day, there are plenty of times where there is little breeze/movement in a landscape and it is usable.
04-25-2015, 04:03 AM   #18
In the Q&A portion of the Press Release Ricoh states Pixel Shift will use the sensor's electronic shutter, so the mirror will stay up. Pixel Shift apparently combines LiveView and IBIS. The limiting factor for FPS is apparently the read speed of the sensor (8.3 FPS on the K-3II sensor). Whether the shutter moves once or four times isn't clear.
Hi monochrome
could you explain this FPS setting on the k3ii a little more i.e. when would you set this or have it in off
Tom G
04-25-2015, 04:04 AM   #19
todd's Avatar
QuoteOriginally posted by jonby Quote
I think if I were using this feature for landscape I would probably always make a 'normal' exposure as well as the pixel-shifted set
this also brings to mind the potential of PS for selective sharpening...
04-25-2015, 04:34 AM   #20
Lens Buying Addict
monochrome's Avatar
QuoteOriginally posted by Tom777 Quote
Hi monochrome
Tom G
In a word, no. I don't know the answers.
04-25-2015, 10:01 AM   #21
I just refer people to the camera manual
applications, dslr, k-3, k3, landscapes, motion, pentax k-3, pixel, pixel shift, shift, shots
Pixel shift and bracketing Spodeworld Pentax K-3 9 04-23-2015 08:56 PM
Optical IS (in lens) vs optical SR (body sensor shift) vs DS (pixel tracking) rburgoss Non-Pentax Cameras: Canon, Nikon, etc. 10 10-20-2014 07:07 PM
Picking filters for multiple lenses and applications jtkratzer Pentax Camera and Field Accessories 9 02-26-2014 11:12 PM
Slideshow applications? StarDust Digital Processing, Software, and Printing 35 12-16-2009 11:32 AM
All times are GMT -7. The time now is 11:56 PM. | See also: NikonForums.com, part of our network of photo forums!
