05-03-2015, 10:49 AM   #16
nozoom's Avatar
QuoteOriginally posted by robertchow999 Quote
This ability was available on my *istDL.
I just read the manual for *istDL, and it says you can delete multiple images at once (which you can do in exact the same manner on K3 if you want). I have a K7, and it works exactly the same way. This is however not the same as "range selection" on the K3. On the *istDL (and all other Pentax cameras I have checked the user manual for) you have to move to each and every single image that you want to select and then push the OK button to select it. If you want to delete 100 images you have to push the OK button 100 times. Range selection works another way and is faster. It works much like shift-click selection in word and other text editors. You move to one end of the range, sett a marker and then to the other end of the range and select all in between with a single click. No need to visit each and every image and select it with the OK button. You can then repeat this to add multiple ranges. Ranges can go into or through multiple folders if you want.
deletion, dslr, image, images, k-3, k-3 allowed range, k-5, k3, page, pentax k-3, range selection, selection
Can't Believe I Didn't Know This (Feeling Stupid) OrangeKx General Photography 31 12-22-2014 11:15 AM
I didn't know Samsung cameras used the K mount Michael Piziak Pentax DSLR Discussion 17 06-08-2014 09:35 PM
Now That We Didn't Get All We Wanted With The K-3... tabl10s Photographic Industry and Professionals 50 10-24-2013 03:04 PM
What you didn't know about the SEC jeffkrol General Talk 5 11-12-2010 02:47 PM
All times are GMT -7. The time now is 01:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
