05-23-2015, 07:52 PM   #1
rayallen's Avatar
Location: Forresters Beach, Central Coast, NSW, Australia
TAV Mode Query
I have recently been playing with TAV mode because I believe it could be useful in certain circumstances.
I have ISO Auto set to 100-3200 but when the aperture and shutter speed combination would overexpose the ISO will not go below 200 even when the 200 is flashing.
I have tried the same thing on my K10D with ISO set to 100-800 and it happily goes down to 100.
I have read the manual and looked at all the settings related to ISO and can't see anything that would help. Am I missing something here? Any ideas?
05-23-2015, 08:04 PM   #2
MadMathMind's Avatar
Do you have something like highlight or shadow compensation enabled?
And yes, TAv mode, a Pentax specialty, is quite useful and one that needs to be employed often!
05-23-2015, 08:12 PM   #3
When "Highlight Correction" is "On", the minimum sensitivity is set to ISO 200.
05-23-2015, 08:25 PM   #4
rayallen's Avatar
QuoteOriginally posted by C_Jones Quote
Ah yes, that was it. Thanks, guys. I knew someone on the forum would know the answer. This is such a valuable resource.
---------- Post added 05-24-2015 at 01:28 PM ----------
QuoteOriginally posted by MadMathMind Quote
Yes, that's what it was. Some of my friends are amazed by some of the great features on my Pentaxes. And I keep telling them about the things they don't have.
05-23-2015, 08:36 PM   #5
TAV mode is what I use almost all of the time when I shoot outdoors. Indoors with a flash head Manual mode is useful.
Enjoy the weekend.
05-23-2015, 08:44 PM   #6
Enjoy the weekend.
Interesting. I use it indoors to prevent the shutter speeds from going too low. I also use with a flash and ND filter to do fill-in flash with large apertures outdoors. I set TAv to 1/250, enable HSS, and dial the NDX filter to hit the ISO between 80 and 200.
05-24-2015, 07:01 AM   #7
Pentaxians's Avatar
I'm using this mode to capture bird in flight in my K-S1. Shutter speed set to 3000 with max. Aperture. ISO auto to 1600, noticed the iso will change accordingly to the lighting condition.
05-24-2015, 09:37 AM   #8
Use of it can depend on light that is present. Outdoor fill-in flash would be an option depending on subject proximity. Using it indoors also is an option depending on lighting conditions, and on user preference. With the flash and umbrella lighting, I have used Manual mode to have control over portrait conditions. I tried using TAV and flash with artificial lighting and had some success, but found Manual mode gave me the results I preferred. I also have used HSS on occasion. For example, I used my AF360FGZ set to HSS when shooting hummingbirds in a group of flowers that was surrounded with large trees. I used my TAV mode then and came up with some nice shots at a good ISO. That type of shooting, with the sunlight varying naturally is where the TAV mode was useful. Other than a situation like that, I use TAV for shooting when I am outdoors without a flash for most shooting. When indoors using controlled lighting, I have found a flash with Manual mode a useful combination. Of course, as per situation, TAV may come in useful in many situations, including indoors, depending on light availability and user preference.
07-01-2015, 11:58 AM   #9
Hi Guys, I have a separate query with TAv mode. I shoot with this mode most of the time. Just wondering if there is a way to use this mode with Manual Lenses. My K-5 Automatically switches to Av mode whenever I mount my Manual Lenses. It would be nice if we could select the F-stop using our lens Aperture ring and just have the Camera work out the ISO for us. My Canon bodies work really well like this - is there a setting I have missed on my K-5 for manual lenses?
07-01-2015, 10:18 PM   #10
ScooterMaxi Jim's Avatar
Keep in mind that Highlight Compensation can be set to Auto, and I have never seen it trigger on the K-3 unless the scene would blow out the highlights significantly. If anything the profile is a bit too conservative and you might still get some blown highlights - so you might still need to utilize some exposure compensation - up to -0.7 in the highest dynamic range situations. In my experience, it doesn't make sense to set the HC on either of the other options; set to Off you surely will experience significant blown highlights in some situations (even in RAW shooting); set to On you will be adding some (marginal) shadow noise at times when the adjustment isn't needed.
dslr, iso, k-3, k3, mode, pentax k-3, tav, tav mode
EV +- in TAv mode? Moropo Troubleshooting and Beginner Help 12 11-15-2014 05:49 PM
Manual mode on my K10D is acting like TAv mode Love my K10D Visitors' Center 9 11-06-2013 11:44 AM
help - TAv shown instead of M mode Breanne Visitors' Center 2 10-28-2013 08:16 PM
Is it possible to use manual flash in TAv mode? ismaelg Pentax DSLR Discussion 3 07-09-2013 11:52 AM
AF360FGZ manual control in TAv mode? ismaelg Pentax DSLR Discussion 2 06-25-2013 08:58 AM
All times are GMT -7. The time now is 01:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
