Show Printable Version 9 Likes Search this Thread
05-26-2015, 06:01 PM   #46
The reason this works (from what I see) is that its taking better/more accurate readings from each pixel. Instead of algorithms producing the 'probably' colour its getting measured information at all zones. The fake 24mp images (in this case 16+8+8) are now true 24mp, with each pixel checked 4 times. Theres still quite some processing going on but the huge leap in data allows for much higher accuracy. The processing can be done in the cameras memory, the system only spitting out the corrected information, so no big file sizes. This is probably what needs to be done for DNG files as they have to comply with existing standards. The PEF can be a new sub-format and include all 4 raw shots of data for later processing allowing for development of both the blending technology and the full image data before output.
A very novel and very pentax approach to increasing the image quality of digital capture. Every camera (with ibis) should have this.
05-26-2015, 06:31 PM   #47
normhead's Avatar
QuoteOriginally posted by bibz Quote
Can we see an example of how it works first? The examples i saw were slight improvements, but not what I would expect going to 36MP would be.
05-26-2015, 06:44 PM   #48
mee
QuoteOriginally posted by Tjompen1968 Quote
That looks really nice. Some weird patterns on a few places but overall nice result.
Yes I think that is where there was a large amount of movement.. for instance on this image at the bottom, left corner right above the vent fan there is a pattern over a tree limb that appears to have been swaying in wind.
http://www.yaotomi.co.jp/blog/used/PENTAX_K-3II_1001.JPG
Interested in how this behave around moving water.. lake or river..
That and MACRO with no movement is going to give phenomenal results for crop body..
05-26-2015, 06:55 PM   #49
Just doing some playing around with pixel shift and the DNGs and PEFs appear to be the same size for me. Got some samples as soon as I find somewhere to upload the fullsize.
Also Lightroom 5.7 appears to read the DNGs just fine.
JPG off: 12.5MB
JPG on: 13.4MB
DNG: 129.1
PEF: 126.9
05-26-2015, 07:17 PM   #50
JohnBee's Avatar
QuoteOriginally posted by eraser Quote
JPG off: 12.5MB
JPG on: 13.4MB
DNG: 129.1
PEF: 126.9
Added some 100% crop examples, the compression of the forum uploader ruins image quality a bit I think.
hmmm... are you sure this is even working?
ie, I don't see any of the image characteristics demonstrated by Pentax in these samples whatsoever.
Perhaps they were sharpened?
05-26-2015, 07:32 PM   #51
QuoteOriginally posted by JohnBee Quote
I think it's working, the differences are very noticeable when viewed at 100%. Uploading to the forums killed the detail I think.
05-26-2015, 07:39 PM   #52
JohnBee's Avatar
Oh okay, that must be it. That said I'd love to see one of those up close.
Would you be interested in uploading a full sized, unprocessed image to my ftp/webserver?
Do you have and ISO100 sample?
If so, I'd be more than happy to host the full size image(s) on the forums afterwards.
05-26-2015, 07:41 PM   #53
And if so, I'd be more than happy to host the full size image on the forums afterwards.
Sure, I just shot three sets jpg/dng/pef samples. The first is up on dropbox, however long that will last.
Also down for request of whatever people want tested.
Edit: Will take an ISO 100 sample
05-26-2015, 07:55 PM   #54
JohnBee's Avatar
Awesome!
PM sent
05-26-2015, 08:54 PM   #56
QuoteOriginally posted by mee Quote
That sample image is very informative. Look for things likely to move and you'll find artifacts when zoomed to 1:1., not just trees.
Check the red Ferris wheel visible behind the center building. Also follow the road and sidewalk. Many people on the sidewalk have pixellated ghosts. The ghosts of fast moving cars are less noticeable because the ghost is so far away from the main car, but you can see a lot near the center road (where distance and viewing angle have the car move fewer pixels across the frame).
---------- Post added 05-27-15 at 12:10 AM ----------
PEF and DNG are uploading, in the meantime some JPGs. Same procedure for all shots, first shot is PS off, AF for first then switched to MF for all following shots in that set with PS ON. Some full size samples (Thanks to JohnBee for hosting):
Thank you very much for sharing those.
The last pair looks like there might have been some tripod movement. http://199.168.184.48/eraser/IMGP0112.JPG was with pixel shift off and it looks like there's motion blur (or maybe I'm just looking at an area that's not in focus). http://199.168.184.48/eraser/IMGP0113.JPG is with pixel shift on, and shows artifacts in tree bark and other things that don't move with the wind.
Your other samples, though, reinforce that pixel shift is for printing not on screen viewing. Fairly low res viewing on a computer screen doesn't need pixel shift's increased resolution, and heavy screen cropping with pixel shift on will make the stacking artifacts obvious. Looking forward to what happens with sharpening. I suspect that our usual sharpening methods no longer apply.
05-26-2015, 09:16 PM   #57
QuoteOriginally posted by DeadJohn Quote
Your other samples, though, reinforce that pixel shift is for printing not on screen viewing. Fairly low res viewing on a computer screen doesn't need pixel shift's increased resolution, and cropping with pixel shift on will make the stacking artifacts more obvious. Looking forward to what happens with sharpening. I suspect that our usual sharpening methods no longer apply.
Looks like possibly some tripod movement yea.
Here is an example of an artifact I found in IMGP0107:
05-26-2015, 10:49 PM   #58
Thank you for the samples, Alex. The PS DNG from the first set with the fence is noticeably better in my raw developer than the matching JPG with PS off. Everything is crisper and the colours are not oversaturated and burnt out, e.g., the dandelion in the JPG. I am convinced that PS works as advertised. Full JPG export is 38.7 MB from the 129.8 MB DNG. I applied my standard sharpening and local contrast boost I use for my K-3 and, to be honest, the result is exceptional.
Alas, the PEF will not open in my raw developer of choice (darktable) - unknown format. I imagine it will be the same for other raw developers until an update to handle the new format is released.
Jack
05-27-2015, 01:17 AM   #59
QuoteOriginally posted by jbinpg Quote
Jack
Wait a minute, are you saying that you can develop the DNG-file in a non Pentax program?
05-27-2015, 01:27 AM   #60
Yes, sir. Loads just like a regular DNG.
artifacts, car, dng, dslr, examples, files, increase, k-3, k3, k3ii, link, magnification, move, movement, note, pef, pentax k-3, pixel, ps, samples, scene, screen, shift, shot, shots, subject
SR and Pixel Shift Technology C_Jones Pentax K-3 & K-3 II 9 05-10-2015 06:24 AM
Pixel Shifting Samples from Pentax on the K3II mikeodial Pentax DSLR Discussion 99 04-26-2015 05:00 PM
Pixel shift practical applications Spodeworld Pentax K-3 & K-3 II 20 04-25-2015 10:01 AM
K-3 II pixel shift resized. Wow factor. JimmyDranox Pentax K-3 & K-3 II 21 04-25-2015 09:37 AM
Pixel shift and bracketing Spodeworld Pentax K-3 & K-3 II 9 04-23-2015 08:56 PM
All times are GMT -7. The time now is 01:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
