05-27-2015, 01:51 AM   #61
Ok, but is it the pixelshifted result you get, or only one of the four exposures? Search for artifacts from moving grass as can be seen in down right corner of picture 0091.jpg
05-27-2015, 02:03 AM   #62
tomtor's Avatar
QuoteOriginally posted by jbinpg Quote
Yes, sir. Loads just like a regular DNG.
That's nice!
Are the demosaic options disabled in darktable?
I would expect that if the equivalent of a 24mpix 16bit rgb image is stored in the k3ii DNG.
I will have a look at the internals of the dng later this day when I am back from work.
---------- Post added 05-27-15 at 11:21 AM ----------
Alas, the PEF will not open in my raw developer of choice (darktable) - unknown format. I imagine it will be the same for other raw developers until an update to handle the new format is released.
Jack
I could work on a darktable PEF fix but I wonder if that is worth the effort because most people (myself included) use DNG.
Are there any users on this forum who would like to see support for this?
05-27-2015, 03:13 AM   #63
kh1234567890's Avatar
Faststone appears to load and render the PEF and DNG files without any problem. Claims they are 6080x4032 for the PEF and 6028x4024 24Mp 24 bit for the DNG.
Rawdigger also opens both and renders them to 4x the resolution of the individual channels as it sees them. In other words, libraw/dcraw is happy with the files.
05-27-2015, 04:17 AM   #64
tomtor's Avatar
QuoteOriginally posted by kh1234567890 Quote
24 bit for the dng means 8 bit per channel, that cannot be right.
That would mean a 3 byte (rgb) x 24Mpixel is about 72 megabyte dng. The file is about two times bigger so we can assume that it really stores 14 or 16 bit for each channel.
Perhaps faststone uses the embedded jpeg preview.
The rawdigger results hints at the following approach. The data is encoded as from a hypothetical 96mpix (4 x 24mpix) bayer sensor. That makes sense.
05-27-2015, 04:22 AM   #65
Barry Pearson's Avatar
QuoteOriginally posted by Gimbal Quote
Wait a minute, are you saying that you can develop the DNG-file in a non Pentax program?
I've done some analysis of one of the DNGs at DPReview:
DPReview: Preliminary Analysis
DPReview: Re-Preliminary Analysis
I used Lightroom CC, the DNG Converter, and "dng-validate.exe" from the DNG SDK.
Bad news. Looks like a screw-up by Ricoh!
05-27-2015, 04:59 AM   #66
QuoteOriginally posted by tomtor Quote
And pressing 'A' in Faststone runs the dcraw based demosaic/render. The files also open in SilkyPix Pro 6 and RawTherapee.
05-27-2015, 05:03 AM   #67
QuoteOriginally posted by Barry Pearson Quote
If I remember correctly for the K3 on their HDR images, Ricoh had a capability within their supplied software - Silkyplex, to unbundle and extract all the associated images for further processing. Might they have done the same with this pixel shifting? Also, on the HDR there is lots of available software to process the multiple frame bracketed shots, but with PS I don't know of any post processing utilities that may provide an additional processing capability. Just thinking out loud....
... Is there anything in the user's manual that addresses this?
05-27-2015, 05:44 AM   #68
tomtor's Avatar
QuoteOriginally posted by eraser Quote
PEF and DNG are uploading, in the meantime some JPGs.
Same procedure for all shots, first shot is PS off, AF for first then switched to MF for all following shots in that set with PS ON.
Some full size samples (Thanks to JohnBee for hosting):
http://199.168.184.48/eraser/IMGP0090.JPG
http://199.168.184.48/eraser/IMGP0091.JPG
http://199.168.184.48/eraser/IMGP0092.DNG
http://199.168.184.48/eraser/IMGP0093.PEF
IMGP0091.JPG shows artifacts on and to the right of the dandelion:
IMGP0092.DNG is from a different moment and has a different composition, so it is hard to compare output from
raw developers. It would be nice if we had the output from a RAW+ session (DNG and matching JPG).
I cannot see artifacts in the darktable produced IMGP0092_01.jpg, so I think it just uses the first 24mpixel data and
ignores the rest.
ISO1250 is also not ideal for quality assesment.
05-27-2015, 06:22 AM   #69
QuoteOriginally posted by interested_observer Quote
My main complaint is that they contravened the DNG specification. That is doomed to cause problems.
I can't find anything in the camera manual. I haven't got the software manual yet, because my K-3 II hasn't arrived yet.
05-27-2015, 06:40 AM   #70
tomtor's Avatar
There IS a bright side, if you use the PS option and the PS failed due to movement then you have access to your normal workflow with the big PS DNG and can create a normal image without the artifacts.
You could also fix the artifact spots in the PS output with a top overlay in photoshop with the non PS result.
I think the only workflow for now is to use the Pentax converter to convert a PS DNG to a 16 bit TIFF or DNG, and process this file in your normal raw workflow,
ie with lightroom or darktable or ...
That would not be a show stopper for me, PS is a specialty after all.
05-27-2015, 06:42 AM - 1 Like   #71
ignores the rest.
Interesting! I shot high ISO for that set because somebody was interested in how it affected the PS. Some of the others are lower ISO.
These are all directly off the SD card and out of the camera. Anything else you want to see?
I am uploading a DNG+JPG combo for you to play with (still uploading so all links may not work):
http://199.168.184.48/eraser/IMGP0122.JPG
http://199.168.184.48/eraser/IMGP0123.JPG
http://199.168.184.48/eraser/IMGP0125.DNG
http://199.168.184.48/eraser/IMGP0125.JPG
http://199.168.184.48/eraser/IMGP0117.JPG
http://199.168.184.48/eraser/IMGP0118.JPG
http://199.168.184.48/eraser/IMGP0121.JPG
http://199.168.184.48/eraser/IMGP0121.DNG
http://199.168.184.48/eraser/IMGP0126.JPG
http://199.168.184.48/eraser/IMGP0126.DNG
05-27-2015, 06:45 AM   #72
clarification
Thanks so much for posting these! To clarify are the DNG and PEF files for each image with PS on, or is the DNG with PS off and the PEF with PS ON (ie. following same order as jpegs)? Thanks, these are very useful samples to start things off!
05-27-2015, 06:52 AM   #73
QuoteOriginally posted by ontariomark Quote
No worries.
Generally, the first jpg in a set I shot with PS OFF and the following DNG/PEF/JPG are with PS ON.
All are directly out of camera with no pef->dng conversion or anything. I changed settings in the menu and took 4/5 separate shots.
IMGP0126.DNG/IMGP0126.JPG are just a DNG+ with PS ON.
I'll do some more samples tonight if wants anything specific.
05-27-2015, 06:57 AM   #74
No worries.
Great, thank you! If you have time I would love to see some raw files with PS off. Subjects that show fine detail and lots of dynamic range--ie. shot of some trees with grass, for example, and skintones if possible. If you have an external flash, I would love to see how fill flash looks towards the sun with a person if possible.
Also very curious how the new AF-C tracking works!
Really appreciate it all this!
--Mark
05-27-2015, 07:01 AM   #75
tomtor's Avatar
Thanks for your efforts, got them!
Created a jpeg with darktable with zero adjustments:
The out of camera PS jpeg is clearly better:
artifacts, car, dng, dslr, examples, files, increase, k-3, k3, k3ii, link, magnification, move, movement, note, pef, pentax k-3, pixel, ps, samples, scene, screen, shift, shot, shots, subject
SR and Pixel Shift Technology C_Jones Pentax K-3 9 05-10-2015 06:24 AM
Pixel Shifting Samples from Pentax on the K3II mikeodial Pentax DSLR Discussion 99 04-26-2015 05:00 PM
Pixel shift practical applications Spodeworld Pentax K-3 20 04-25-2015 10:01 AM
K-3 II pixel shift resized. Wow factor. JimmyDranox Pentax K-3 21 04-25-2015 09:37 AM
Pixel shift and bracketing Spodeworld Pentax K-3 9 04-23-2015 08:56 PM
All times are GMT -7. The time now is 01:06 PM. | See also: NikonForums.com, part of our network of photo forums!
