05-29-2015, 01:01 AM   #1
tomtor's Avatar
Implementing automatic artifact removal from PS shot in dcraw
I am considering to adapt the dcraw program so that it can convert Pentax k3ii Pixel Shift shots and I would like some feedback on the possibility of removing artifacts caused by subject movement.
The green channel is captured twice, so the idea is to detect motion by comparing the brightness of each matching pixel in these two green exposures. If they differ then the subject has changed and on that location the normal bayer interpolation is used.
Could that work?
05-29-2015, 02:26 AM   #2
Will this be a Pentax proprietary DNG to linear DNG converter?
05-29-2015, 03:54 AM   #3
tomtor's Avatar
QuoteOriginally posted by StigVidar Quote
Dcraw converts to 16 bit Tiff.
05-29-2015, 04:15 AM   #4
This will be too sensitive to noise. Try Lucas-Kanade optical flow methode, that my help to get a vector field of movement.
05-29-2015, 04:27 AM   #5
tomtor's Avatar
QuoteOriginally posted by 08amczb Quote
Yes, noise is an issue, but my proposal is more simple to implement. Advanced analyses will not be made a part of the standard dcraw code, I'm afraid.
Ofcourse everyone is welcome to write his own smarter code.
I would trigger the movement detection with a threshold, eg when the two green readouts differ by 10%
05-29-2015, 05:23 AM   #6
I wonder if it’s not better to just convert the file without any automatic editing at all. And then let the user take it from there. At least have the option to convert without messing with the data.
05-29-2015, 05:37 AM   #7
Will this be a new branch from dcraw or will it be standard dcraw functionality?
05-29-2015, 06:08 AM   #8
tomtor's Avatar
QuoteOriginally posted by Gimbal Quote
Yep, I will start with a non messing implementation.
---------- Post added 05-29-15 at 03:10 PM ----------
That is not for me to decide.
It depends on the original dcraw author (Dave Coffin) if he is willing to adopt the code for this special Pentax feature.
I could use some help in detecting a PS DNG file.
Is there an exif hint which makes it clear that PS was active?
I could use the filesize (>100megabyte) as a hint, but that is less elegant.
05-29-2015, 06:55 AM   #9
QuoteOriginally posted by tomtor Quote
Dave Coffin has a parse.c program that might be useful, but I don't know if it tries to parse everything or only already known exif and ciff data.
05-29-2015, 07:21 AM   #10
If somebody with a new camera can send you a non pixelshifted and a similar pixelshifted DNG , they can be compared, for example:
$ exiftool -g -u imgp4006.jpg > K3ps.txt ; exiftool -g -u imgp4004.jpg >K3nops.txt ; diff K3ps.txt K3nops.txt
where -u provides all the unknown tags
05-29-2015, 10:27 AM   #11
tomtor's Avatar
QuoteOriginally posted by wombat2go Quote
I'll just use the number of embedded raw images (4) to detect the PS DNG...
05-31-2015, 02:59 AM - 4 Likes   #12
tomtor's Avatar
First implementation
I finished an initial version:
http://www.v7f.eu/public/pentax/dcrawps.c
Example usage:
dcraw -T -4 IMGP0121.DNG
IMGP0121.DNG was posted with other files in this thread:
https://www.pentaxforums.com/forums/172-pentax-k-3/296122-k3ii-pixel-shift-first-test-5.html
By default it wil detect artifacts by unexpected changes in the green channel.
Artifacts are repaired by the bayer interpolation on the first image.
-G sets the threshold, by default 10%. -G 1000 will disable, -G 20 sets the threshold to 20
By specifying -v it will highlight the spot in purple. This can also be usefull if you want to repair manually.
The example file has a moving tick
-- edit --
And a compiled windows version:
http://www.v7f.eu/public/pentax/dcrawps32.exe
05-31-2015, 05:55 PM   #13
Class A's Avatar
I finished an initial version.
That's great stuff, thanks a lot for sharing!
Really cool idea to use the green channel to detect motion.
artifact, artifact removal, dcraw, dslr, k-3, k3, k3ii, pentax k-3, pixel, ps, raw, removal from ps, shift, shots, subject
Removal of lens from K2000 Dewman Troubleshooting and Beginner Help 12 06-12-2014 04:44 PM
Dust removal from lens bassek Pentax SLR Lens Discussion 9 08-02-2013 02:33 AM
From PSE to PS CS5 kitkat Troubleshooting and Beginner Help 2 05-24-2011 11:06 AM
From PS Elements 5 to 7 questions OrenMc Digital Processing, Software, and Printing 11 04-12-2009 06:08 AM
Got PS CS2; wanta try PS CS3 Beta? jfdavis58 Photographic Technique 3 12-15-2006 09:42 PM
All times are GMT -7. The time now is 10:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
