06-02-2015, 11:14 AM   #1
Pentax K-3 'wobbly' (?) mode dial
I got a new K-3 last month. Now I just noticed that the mode dial 'wobbles' quite a bit. I also have the K-50, Canon G1x, and other Point-and Shoot cameras; and the mode dials on those cameras are not as 'wobbly' as the K-3.
I checked out 2 other K-3s in stores and they are similar.
Is this normal? Seemingly, the Olympus OMD-EM5 also has this "wobbly mode dial" characteristic...
06-02-2015, 01:17 PM   #2
Welcome to the Pentax Forums!
Hmmmm...I just did checked my K-3 as well as those 15 film bodies (dating to late 1950s) from my collection that have a shutter speed or mode dial. All but three of those cameras share a similar amount of wobble or "rocker". Those three that do not wobble are the Canon P, Zorki 4K, and FED-2 rangefinder cameras, though I should note that both the Zorki and the FED have a bit of side-to-side play that was missing on the other 14 bodies. Perhaps it is because of their shared Soviet heritage.
Without actually fiddling with your camera, I can't say whether it is normal or not. Mode dials often are spring-loaded to some degree and that might be a potential cause of wobble, though excessive movement might be evidence of damage to the body from impact or having been dropped.
P.S. I no longer have my Canon G2 digital, but IIRC, it too had a mode dial that wobbled a bit. I don't remember if my recently departed K10D had the characteristic.
06-02-2015, 07:51 PM   #3
QuoteOriginally posted by Poompat Quote
I just checked my recently-purchased K-3 and the mode dial does have a bit of "wiggle". It's not been an issue to me and I likely wouldn't have noticed it (but you just *had* to go and bring it up . I attribute it as an artifact of the mode dial lock button and lock lever. My K-50 mode dial doesn't "wobble", but then again that dial doesn't lock in place.
06-03-2015, 12:21 AM   #4
This seems normal indeed. My K-3 always exhibited more of a wobble on the mode dial than previous models as well. The new K-3II (arrived last WE) seems to be slightly better, though I will only know for sure after some time using it. This wobbliness never caused any problem on the K-3 however.
Wim
06-03-2015, 11:06 AM   #5
Thank you all for responses.
cameras, dslr, k-3, k3, mode, pentax k-3
Pentax K-7 Front e-dial in Manual Mode Photobuddy25 Troubleshooting and Beginner Help 3 05-02-2015 12:40 AM
K-50 Rear e-dial jam (Av mode)? ps1984 Pentax K-30 & K-50 4 04-14-2015 01:13 AM
K-30: Lost Manual Mode on E-Dial knightzerox Pentax K-30 & K-50 7 12-06-2013 11:31 PM
Pentax K-r Mode Dial Issue jaznina Troubleshooting and Beginner Help 2 03-01-2013 08:42 AM
Pentax K-x mode dial decal for your laptop/macbook/ipad/netbook commo Pentax DSLR Discussion 8 09-18-2010 09:56 AM
All times are GMT -7. The time now is 01:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
