06-04-2015, 09:44 AM   #16
QuoteOriginally posted by ontariomark Quote
So bummed, I just took delivery of a Pentax K3ii with 50mm lens (coming from Nikon camp). The camera works well overall, but when you attach an external flash (I've tried Pent af-540GZ), there is a noticeable lag before the camera will actually take a picture. Release priority selected on all focus modes. I thought maybe I was doing something wrong, but a quick search reveals 17 pages of forums comments on this issue with the K3. Did anyone ever find a solution. Does anyone know if the KS2 has this issue? My local stores don't carry Pentax to try.
I noticed the issue on my K3 when I got it a year ago. I do not do much on camera flash work so it did not bother me. I thought I was imagining things when it happened but I guess it is a known issue. If I did event work or work that required on camera flash, the lag would drive me crazy... you can miss a lot of split moment shots with this problem. For the life of me I can't understand why a world class pro camera should have a problem like this.
BTW, I have a 540 and a 360 and the problem is with both. I also have a Metz 52 AF-1 but I do not remember if K3 behaved the same way with the Metz.
06-04-2015, 12:58 PM   #17
ScooterMaxi Jim's Avatar
QuoteOriginally posted by btnapa Quote
It has nothing to do with the model of flash used, or the particular firmware (unless recently addressed in 1.21- which is highly doubtful). The Ricoh/Pentax engineers had a decision to make after the K-5 series fiasco - highly irregular flash performance without a lag (K-5), or consistent flash performance with a lengthy lag - and chose the latter. Actually, the design of the K-01/30/50/500 is the least offensive pTTL to date - I'd rate it mediocre as opposed to all other implementations which disqualify it for consistent, critical professional work. Many Pentaxians say they can live with it, but they apparently have no desire to the mental workarounds and they tend not to have come from the systems that have fewer issues - Nikon is the best of the lot.
06-05-2015, 12:30 PM   #18
The daft thing about the lag is that it is before the camera does anything at all. I could possibly understand if it does a preflash immediately then spent some time analysing the image of the preflash captured by the 86k sensor but it is not so.
You press the shutter, nothing detectable at all happens for a full 200mS or so then the preflash then almost immediately the mirror lifts, shutter opens and main flash fires. I had suspected it might be due to slow and/or inefficient communication between the flash and the camera but then I actually monitored the connections and found that there is no signal at all exchanged between the camera and flash in those first 200mS after pressing the shutter button, then after the delay everything happens in very quick succession practically as fast as mechanical limitations of the mirror, iris and shutter allow.
06-05-2015, 12:42 PM   #19
enoeske's Avatar
QuoteOriginally posted by lister6520 Quote
That's pretty interesting. I always viewed it as a bug, and not as a compromise to ensure consistent P-TTL.
06-06-2015, 07:31 AM   #20
Larrymc's Avatar
Hmmmmm. I just checked my K-3 with 1.21 firmware and I notice no appreciable delay when shooting P-TTL in manual mode. In AV and TV mode still no noticeable delay. I use a Sigma EF 610 DG super P-TTL flash unit. Could the problem lie with the Pentax branded flash units?
06-06-2015, 09:17 AM   #21
OK, enough of you are seeing that there is no lag that I decided to try it out with the new firmware 1.21 - and here's my total mea culpa. The problem is gone! The exposures are spot on. Spot on in direct (who uses that?), spot on in bounce, spot on with exposure compensation, spot on with wider apertures. No discernable lag. Shooting with the on-board flash - works fine. Shooting with an external, cheap generic flash - fine. The firmware fairy has done it. The irony is that Pentax has so little confidence in the flash system, they're taking away the on-board flash (K-3ii) at the precise time when it can prove most useful.
Keep in mind, flashes are relatively dumb - the camera controls both pre-flash and exposure flash. So all properly functioning pTTL flashes should perform similarly. Pentax has had so much egg on its face regarding the flash system that I guess the firmware improvement doesn't warrant drawing attention to the obvious fix. That's sad.
06-06-2015, 09:47 AM   #22
Otis Memorial Pentaxian
QuoteOriginally posted by enoeske Quote
One person's bug is another person's feature. With any luck the two comments above are accurate and this tragic, horrible, negligent, fatal, (insert appropriate adjective here) flaw has been corrected with room for happiness for all.
06-06-2015, 09:50 AM   #23
FWIW, ScooterMaxiJim has started a new thread specific to firmware v1.21 as a fix for this issue on the standard model K-3.
https://www.pentaxforums.com/forums/172-pentax-k-3/297103-flash-lag-fixed-fw-1-21-a.html
06-07-2015, 04:16 AM   #24
Didn't work for me
First image is P-TTL with 1.02
Second is manual with 1.21
Third image is P-TTL with 1.21
No discernible difference between 1.02 and 1.21 in terms of lag but huge difference between manual and P-TTL regardless of firmware version. Still way too slow in P-TTL to capture 'spur of the moment' shots, which is when I need P-TTL most.
Not sure what's happening with the exposure probably nothing to do with the firmware upgrade - possibly inadvertently different orientation of the flash head before and after the update.
06-09-2015, 12:56 AM   #25
Hello. I do not see the picture
behavior, camera, dslr, flash, focus, issue, k-3, k3, k3ii, lag, modes, pages, pentax, pentax k-3, pentax k3ii, pttl, thread, user
645Z has long shutter lag at Live View mode thomaskplee Pentax Medium Format 7 01-11-2015 02:04 AM
Pentax DSLR Shutter Lag geekette Pentax DSLR Discussion 11 04-13-2012 09:54 AM
External flash problem Unregistered Visitors' Center 4 02-12-2012 05:57 AM
Has the exposure problem with flash been solved? Naim Khan Pentax K-5 & K-5 II 35 02-05-2011 07:04 PM
Brother messes wiht my camera= Shutter lag problem NYpHoToGraphEr Pentax DSLR Discussion 10 12-29-2007 01:59 AM
All times are GMT -7. The time now is 05:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
