Originally posted by Adam Sounds like the mirror flop issue. Perhaps the K-3 II doesn't shut itself off when it happens, unlike the K-3 (after firmware update)?
Given the OP reports flapping on half press this is not the same conditions as cause the K3 issues.
It is a lot closer to the k5 issue burn't out Voltage regulator and as such would indicate a broken camera.
All cameras Nikon, Pentax Canon etc will flap the mirror for certain conditions some of the obvious are
1 shutter/mirror sync
2 Mirror not seated
The k5 had two known failure casues
1 Regulator failure
2 mirror box worn
The k3 has 1 known and 1 'bug'
Known
Stiff mirror will cause flapping
unknown
appear to be a parameter issue in the Mirror logic
FW 1.11 is as we know a remediation for the unknown 'Bug' and will squalch the runaway flapping
I doubt Ricoh have altered the correct behavior with this firmware so a camera with 'sync' issues or overly tight bearings will flap irrelevant of firmware until the mirror/shutter are in the correct positions.
The OP needs to return the camera hopefully as a DOA but given '2 weeks' he may have to accept a repair (dependent on in country law)
