06-17-2015, 08:48 AM   #1
Just ordered K-3ii
B&H had K-3ii for $980 so I decided to jump at it. I see some threads stating there are K-3ii problems, but it seems like every new release has that. The K-5 had that horrible sensor stain issue, but I waited a while for that to resolve. Can I use the same batteries that I have for my K-5? They look like the same specs.
06-17-2015, 09:26 AM   #2
bwDraco's Avatar
The same batteries will work as they're the same D-LI90. In fact, if you have a D-BG4 battery grip, the same battery magazines will work in the D-BG5 and vice versa.
—DragonLord
06-19-2015, 03:34 PM   #3
File naming in camera
With my K-5 I used the default file naming which is XXX_MMDD (folder number followed by the date) and inside the folder each file is _IGPXXXX. I keep each Memory Card in a separate folder. When I import into Lightroom the files are named YYYY-MM-DD_IPGXXXX (full date followed by the image number used in camera). Now that I'm getting the K-3ii I'm reevaluating my file naming system. I tag all my photos when I import so I do not need descriptive file names. What do you do for your in camera file naming and database file naming?
06-19-2015, 03:45 PM   #4
QuoteOriginally posted by Jool Quote
In camera, files are named K5_99999
When exported after PP in Lightroom, K5_99999 <descriptive name>
That way I can always find the RAW file if I ever want to reprocess.
- not perfect but it works for me.
06-22-2015, 08:13 AM   #5
GPS question
I will be getting my camera today. Reading the manual online it has directions on how to calibrate the GPS. Do I have to do that initially to get the GPS to work correctly or only if it is not working correctly?
06-23-2015, 06:22 PM   #6
viewfinder question
I finally got my K-3ii. I noticed that the eyepiece that you look through is a little crooked. Does that affect the view through the viewfinder or is it just a place to rest your face/eye against and doesn't affect the actual view that you see through the camera and lens? I looked at my K-5 and it is perfectly straight. I'm guessing that it's not a problem but I want to make sure. I don't want all my pictures to be crooked.
06-24-2015, 03:39 AM - 1 Like   #7
The external eyepiece surround actually slides up and off so it can be replaced with a blank viewfinder cap for use in long exposures. Gently but firmly, push down on the 'high' corner and it will straighten. The rubber/plastic eye-piece doesn't affect the view through the prism. It's stiff to slide off but quite thin, so be careful.
06-24-2015, 11:38 AM   #8
Wow, how stupid of me. I thought that was part was fixed to the camera and that the rubber eyecup was only removable. Thank you for the reply.
dslr, k-3, k-3ii, k-5, k3, pentax k-3
Just ordered the FA43 1.9 for my K-3 dcpropilot Pentax K-3 13 03-08-2015 06:48 PM
Confession: just ordered a K-3 Volker76 Pentax DSLR Discussion 50 12-24-2014 10:35 AM
Just Ordered a K-5ii…need some lens and sensor input zx-m Pentax DSLR Discussion 14 09-21-2014 04:24 PM
Just ordered my K-5ii... tele_pathic Pentax K-5 8 07-03-2013 05:17 AM
Just ordered K-5... reytor Pentax K-5 14 11-28-2011 06:09 PM
All times are GMT -7. The time now is 03:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
