06-22-2015, 04:40 PM - 2 Likes   #1
K-3 II Super Resolution Example
I just shot this and added it to our article on pixel shifting.
Here's what it's like in a web-size crop. The ornament fills about 1/3th of the width of the original frame.
Conventional:
Pixel shifting:
06-22-2015, 06:17 PM   #2
Conventional:
Attachment 273022
Pixel shifting:
Attachment 273023
The difference is obvious... Very impressive... The DXO one seems to have similar approach and it improves the sensor score from 1 inch to aps-c. It sounds here that this super shift will do the same thing and shift the performance from aps-c to a ff with 36mp.
06-22-2015, 06:29 PM   #3
QuoteOriginally posted by starjedi Quote
Having compared the results to a photo shot with the D800 I'd say pixel shifting still falls short of 50% higher sensor resolution and larger pixel pitch, but it definitely comes close for these stationary subjects. There a few more examples on the homepage. I'm impressed by how seamlessly the K-3 accomplishes pixel shifting- it feels like taking a regular photo and only takes a few extra seconds.
06-22-2015, 06:58 PM   #4
Location: As I said before, I quit this forum due to people so rude to each other. Bye!
Thanks Adam for the pictures! I'm glad I dropped my money on the K3 II instead of the cheaper K3! Hopefully my kids can stay still enough for their better portrait picture!
06-22-2015, 07:30 PM   #5
Thanks Adam. There's certainly a huge difference in this example - almost makes the non-PS shot look out of focus. Which lens was used here?
06-22-2015, 07:54 PM   #6
Thanks mate appreciate your work. I look forward to recieving my camera, still saving and waiting for a few bugs to be ironed out first.
06-22-2015, 07:57 PM   #7
johnhilvert's Avatar
It's great to see Ricoh-Pentax innovating with its capture technology.
My take is that it is, at best, a niche feature.
If you have to shoot everything on a tripod and does not work with moving objects, I wonder if I'd use it.
If sharpness at this magnification is such an issue go for full-frame instead.
06-22-2015, 11:14 PM   #8
LightBug's Avatar
Holy Smokes Batman! I'm impressed! I wonder if this will work for long exposures, which may take 4x as long?
06-23-2015, 12:55 AM   #9
Kind of fall into line with johnhilbert's comments.
It is a pity the technology is limited to static subject use. For landscapes, if you are hoping to improve definition of fine detail like leaves/foliage, then anything short of dead still weather will likely undo the technological gains. And we know how often the weather wants to be cooperative with our photographic intentions...
Macro imaging might be a good practical candidate for use of pixel shifting - macro lens typically offer excellent sharpness to start with + subjects are likely to be still for the time it takes for pixel shifting, although it would be interesting to see if flashes could keep up.
And although pixel shifting can also help reduce noise when shooting at high ISOs, if limited to static subjects, why not just shoot at low ISO in the first instance given the photographer is likely already using one of those fancy three legged devices, they're called tripods I think, and avoid altogether high ISO noise problems. Night cityscapes might be an instance where there would be a benefit from a combination of low ISO + pixel shifting noise reduction, provided all elements of the composition were static.
However, we are seeing only the initial 1st generation implementation of this technology. As sensor read speeds improve over successive generations of cameras, the lag between images will reduce and the effects of movement will diminish. In ten years time we will probably look back at this current debate with mild amusement!
06-23-2015, 02:37 AM   #10
QuoteOriginally posted by johnhilvert Quote
I guess I think it wouldn't be that hard to combine images in places where there are artifacts. As for the tripod thing, most good landscape photographers use a tripod for their images. Being able to use lower iso is probably as important as anything to maintaining resolution and dynamic range and leaving your tripod at home is the best way to end up shooting at iso 800 in the early morning hours (or higher).
06-23-2015, 03:28 AM   #11
The pixel shifting things didn't really interest me- it's not something I'd see myself using.
But I have to admit I've been pretty impressed with some of these examples.
06-23-2015, 05:13 AM   #12
loco's Avatar
I'm anxious to see how this technology improves over time. I admit to being wowed by some of the examples, yet as others have said, if it requires perfect stillness, I'm not sure I'd get much use out of it. My main interest would be for landscape type shots. However, if I should find myself in the market for a new camera, having this capability certainly would be a nice bonus.
07-19-2015, 03:33 PM   #13
Hi Adam,
can you give me some details to the "super resolution". Does it use the mechanical shutter or the electronic shutter ?
So, if you take a picture with super resolution do you hear the shutter four times, like you can hear it three times when using HDR ?
Or is it an electronic shutter like a movie, so you hear it only once ?
07-19-2015, 07:43 PM   #14
Pixel shift may be a niche feature but it is powerful never the less. If you are a macro shooter I can see this as very useful. Maybe useful for interior architecture as well.
Filling little niche markets is a reasonable idea as it seems wholesale innovation is receding in the digital imaging area at the moment.
If they can add the Olympus function as well in a future model that would be great as well.
Howie Be
07-19-2015, 08:43 PM   #15
QuoteOriginally posted by howieb101 Quote
Agreed.
There are *lots* of little niches out there where this enhanced detail and colour reproduction might be useful, and where the use of a tripod isn't a big deal. Macro of course, but also architectural exteriors, real estate, product shots, studio still life, food photography, document reproduction, crime scene photos , camera attached to a microscope etc etc.
Lots of little niches can add up to decent sales.
dslr, ii super resolution, k-3, k-3 ii, k3, pentax k-3, pixel
K-3/k-3 ii iso Dr. Zee Pentax DSLR Discussion 27 06-24-2015 11:54 PM
AF.C on K-5 II vs K-3 StigVidar Pentax DSLR Discussion 2 06-22-2015 09:57 AM
Super resolution in post process lmd91343 Photographic Technique 11 03-02-2015 10:10 AM
K-3 / K-5 II / K-50: Don't forget the extended warranty! Adam Pentax Price Watch 69 01-07-2015 12:56 AM
Sensor noise on the K-5 II vs K-3 groovyg Pentax DSLR Discussion 24 12-18-2014 03:45 PM
All times are GMT -7. The time now is 11:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
