06-27-2015, 12:59 PM   #1
GPS question
Before I turned the GPS on I went into the Menu and selected calibration. The message was to rotate the camera in three different ways. After I did the first rotation I got a message that it was calibrated correctly without doing the other rotations. Has anyone else had this experience? I'm wondering if it actually did calibrate correctly. Is the location information somewhere on the top or back panels/screens? Also, I've read 3 different responses to how often the calibration has to be done. One was every time the camera was turned off and back on. Another was only if you moved to another location fairly far away. The last was when the battery is removed and then put back in. I hope it's not every time the camera is turned on.
06-27-2015, 02:01 PM   #2
bavd's Avatar
QuoteOriginally posted by Jool Quote
My k3 and o-gps does the same. Even when using astrotracer and precise calibration it will say "calibrated correctly" after just one or two rotations.
Actually i am under the impression that the calibration procedure is just for the compass function. So i don't think it will affect the gps .
But i might be wrong.......
06-27-2015, 02:03 PM   #3
Ole
Ole's Avatar
What gets callibrated is the electronic compass. It is important to do each time you want to use the Astrotracer function. Other than that it isn't critical to redo the callibration unless you rely on or care about the compass (as I recall the direction in which the camera is pointed gets recorded in the EXIF).
The location is displayed on the status screen on the rear monitor (assuming you're talking K-3 II). Hit the INFO button twice and select that screen.
06-27-2015, 02:10 PM   #4
Stone G.'s Avatar
On a K-3: Press the Info-button and select "Detailed Information". Scroll down to the second info-page and you will find information on geographical co-ordinates and compass heading. You can also check the accuracy by loading your images to the 'Geosetter' software (freeware) where you can see your position and heading as an overlay on Google Maps.
For simple calibration, one or two rotations may sometimes suffice. If you are insecure, try to re-calibrate and check if coordinates and heading have changed significantly.
But I would defintely calibrate each time I power up my camera - if you want heading to be accurate. You don't need to do it if you just wake the camera from sleep-mode. Anyway, simple re-calibration normally just takes a few seconds, so I do not consider that to be a big deal.
And yes, if your O-GPS1 battery goes flat during use, you must recalibrate after you have inserted a fresh battery in the O-GPS1 unit.
http://www.gyes.eu/documents/pentax_gps_unit_o-gps1_manual.pdf
calibration, camera, dslr, gps, k-3, k3, location, message, pentax k-3, time
O-gps-1 question chris seager Welcomes and Introductions 8 09-16-2014 09:21 PM
Pentax GPS-01 Question oxidized Pentax Camera and Field Accessories 11 01-15-2014 05:51 PM
Pentax O-GPS1 GPS - Faulty k-5 or GPS Unit? KansasHorizons.com Pentax Camera and Field Accessories 6 01-04-2014 02:34 PM
Pentax K2000 GPS question? Mcid3 Pentax DSLR Discussion 2 02-16-2013 03:47 PM
GPS question and recommendation Newmoon Pentax Medium Format 3 03-28-2012 10:35 AM
All times are GMT -7. The time now is 10:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
