Originally posted by rawr And something like spot metering might directly effect your AF if, for example, you decide to link your metering to your AF point, as you can choose to do [Menu > C1 > 5. Link AE and AF point].
Originally posted by stevebrot I just gave the feature a test drive and with exposure set to the AF point and spot meter selected, the location of the "spot" is very narrow and located at the point of focus rather than the frame center (very cool).
Turns out in works the other way around for the case where AE and AF are linked. The AF point drives the bias of the metering. I would strongly doubt that with the menu setting on default (no linkage), that spot metering would affect focus point selection* or focus tracking behavior.
* I was able to test this with focus is set to A-27 and meter to spot using AF-S. The focus point selection was the same in my test scene regardless of the meter was in spot, center-weight, or matrix. Likewise, metering was identical regardless of the focus point.
