08-05-2015, 07:08 AM   #1
MyTZuS's Avatar
ICC profiles of the K3 & K3II
Hello, I use Capture One software to process my raw files (.dng).
I have a K3 II but not a K3.
There is no ICC profile in Capture One for the K3 II. So, I tried the profiles for the K3. They are very over saturated, so, this leads to my question.
Is it the software or is the software showing me that the info produced by the K3 II is less/more than the K3. Is it showing me inadvertently that the K3 II processes the color space differently than the K3?
Is there more to the K3 II than Pentax/Ricoh has let on?
08-05-2015, 08:50 AM   #2
enoeske's Avatar
QuoteOriginally posted by MyTZuS Quote
Isn't the ICC profile for calibrating your monitor, not for developing RAW files?
08-05-2015, 09:43 AM   #3
He meant Camera color profile embed from the Capture One Pro not ICC color profile for monitor/printer. The camera color profiles depend on the software developers. Adobe Lightroom has it's own color calibration, so is Capture One Pro. Mostly they use particular camera in the studio setting, took a photo of color checkers, and calibrate accordingly. But man power and resource is very limited so normally they just do a "generic" color curve per camera.
I normally would go in, pick the one color curve I like the most (as base), then tune up my own curve saved as default.
08-05-2015, 02:12 PM   #4
slip's Avatar
In order to have maximum colour control, you are best to purchase a x-rite passport and generate different profiles for different cameras and lighting conditions
Randy
08-06-2015, 07:49 PM   #5
MyTZuS's Avatar
But why would a K3 calibrate differently than a K3 II? If a software company uses the same controlled environment, if all other things equal (like the same sensor in both cameras), then why?
08-08-2015, 02:01 AM   #6
Cameras need dedicated support in Capture one.
If a certain camera model is not properly supported, the software won't recognize the raw files, and won't apply the right tonal curves, it won't really help just choosing a camera profile from a supported model. If you go into the Capture one software package, you will not only find camera profiles for each camera, but also a set of tonal curves.
Best thing is to open a support case with phase one to speed up support for the K3II, as they do tend to take a while on supporting new cameras.
Chris
08-08-2015, 07:03 AM   #7
There is a facebook group called capture one collective, they should be able to answer questions like this too, the do a lot of tech support. I still haven't made the switch but I follow the group
08-08-2015, 06:30 PM   #8
6BQ5's Avatar
Capture One produces very saturated images if you use one of the "Auto / Film Extra Shadow / Film High Contrast / etc" curves in the Base Characteristics tool (i.e. same tool where you select the ICC profile). I always use "Linear" which give a somewhat soft, bland image to start with. It's almost like the complete opposite problem to have. I sprinkle a little bit of contrast, saturation, clarity, and highlight/shadow adjustment for each shot. You don't need much, honestly. A little bit of everything together works very well. Try something like 7 for contrast, 2-4 for saturation if necessary, 15 for clarity, and 10 for structure. Season the highlight and shadows to taste. Sometimes I add +30 of shadows and +30 to +100 for the highlights. Don't be fooled by the high number there. The adjustments must be happening in very fine steps and there are a lot of them between nothing and full strength.
I use the default K-3 ICC Profile in Capture One with no desire to make my own.
08-09-2015, 09:41 AM   #9
MyTZuS's Avatar
Thank you everyone for the posts. Learned a lot. What a great forum.
Guess until Capture One puts out a profile I'll keep using the DNG Neutral profile. I really like how Capture One processes raw files (huge files, much more than Adobe). I use it for a couple of tweaks & then finish it up in Camera Raw and/or Photoshop.
dslr, icc, icc profiles, ii, k-3, k3, pentax k-3, profiles, software
K3 or K3ii bessa66 Pentax DSLR Discussion 17 07-09-2015 11:42 AM
ICC Colour profiles Chaos_Realm Digital Processing, Software, and Printing 31 10-04-2011 08:30 PM
OS X printer sharing and icc profiles mysticcowboy Digital Processing, Software, and Printing 3 06-23-2010 02:17 PM
Firefox supports ICC profiles WerTicus Digital Processing, Software, and Printing 17 11-06-2009 07:56 AM
Trying to understand ICC profiles Shogo Digital Processing, Software, and Printing 2 07-30-2008 09:35 AM
All times are GMT -7. The time now is 12:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
