08-05-2015, 07:42 AM   #1
lavascript's Avatar
K-3 locking up
I'm aware of the mirror-flapping K-3 issue, but mine is misbehaving differently.
My new K-3 has completely locked up on me twice. Both times, I had zoomed into a photo 100%, and was holding the Up button to scroll to the face. The green arrow stays highlighted, and the camera will do nothing else. No buttons respond, turning it off makes no difference. I have to pull the battery. Unfortunately, I'm shooting with a grip, so pulling the battery is annoying.
Anyone else experience this?
I'm wondering if I should send it back to B&H or go ahead and send it for service (pre-emptively getting the mirror issue fixed as well)
Relevant info:
Quick Zoom: 100%
SD1: Sony 32GB UHS-I (DNG)
SD2: EyeFi Mobi 8GB (XS JPG)
08-05-2015, 08:35 AM   #2
QuoteOriginally posted by lavascript Quote
Only time I had what sounds like the same problem you describe I was also using the grip. Happened over a year ago, but never since. I suspect it was grip related.
Are you running the latest firmware? (v1.21)
08-05-2015, 09:04 AM   #3
lavascript's Avatar
No. Duh, why didn't I think of that?
08-05-2015, 01:24 PM   #4
There have been periodic reports of lock-up with the K-3. I had it happen three times in the first 10,000 exposures with no apparent cause. There would be no harm done in sending the camera back to B&H (I probably would), though it would be no guarantee that the replacement might not lock-up as well at some point.
08-05-2015, 01:55 PM   #5
This sounds like the kind of issue that a firmware fix might address Hopefully it does.
May also be the eye-fi card draining too much power, but I doubt it.
08-06-2015, 06:51 PM   #6
ImageCircle's Avatar
This is the new "Vegetable" mode found in the K-3. That mode would happen to me early on when I was switching between live view and to regular mode. I also had a manual lens on. Not sure if that made a difference.
08-07-2015, 04:18 PM   #7
6BQ5's Avatar
I think the K-3 tends to draw huge amounts of power in between switching functions like LiveView vs. OVF, shooting vs. playback, etc. These spikes cause the battery voltage to take a dive if your charge is not at 100%. If your voltage suddenly falls I think the camera starts to shut itself off to prevent damage ... but then the the battery level rises! It didn't finish saving internal data before shutting down but starts trying to work as normal. Now the camera is caught in limbo with the firmware not knowing what to do so it freezes.
That's my uneducated guess.
08-13-2015, 12:35 AM   #8
My K-3 has had this problem several times. Over 10 times during the past 10 months. I have updated the firmware and it has nothing to do with it. I suggest it is the hardware problem.
I also sent my camera to inspected and prepared in June. Pentax care in Sweden did not find anything wrong with it.
It happens with several lenses both automatic kit-lens, old fixed Pentax-A SMC and manual Tamron Adaptall2 lenses. I shoot a lot with CIF and with manual lenses it has always happened with it, but that is not the case with the kit-lens. With the kit-lens it happened, when I swithced from aperture priority to manual mode. I have used both Pentax and replacement batteries.
Someone suggested, it could be caused by the bad contact between the camera and the lens. Perhaps.
battery, dslr, issue, k-3, k3, pentax k-3
K3 Locking Up (while shooting time-lapse) DRabbit Pentax K-3 118 03-25-2015 06:18 AM
K-3 with battery grip locking up gosman Pentax K-3 12 04-10-2014 04:04 PM
K5 locking up SenorBeef Pentax K-5 51 09-15-2012 04:52 PM
K-5 locking up yesterday, now... melvis2 Pentax K-5 21 07-16-2011 03:26 AM
Camera locking up BeerCan Pentax DSLR Discussion 4 05-07-2008 04:54 AM
All times are GMT -7. The time now is 04:41 PM. | See also: NikonForums.com, part of our network of photo forums!
