08-06-2015, 02:54 PM - 1 Like   #1
K3II Pixel Shift ISO 6400
I tried an outdoor pixel shift at ISO 6400 and noise was quite good. I needed the high ISO because it was shot at 1/640 sec and f11.
PENTAX K-3 II  Photo
08-06-2015, 03:48 PM   #2
clockworkrat's Avatar
It's a nice picture, but why did you have to use such a fast shutter?
08-06-2015, 03:52 PM   #3
Wind can blow the flower in a long exposure so I was trying to avoid that
08-06-2015, 04:09 PM   #4
I'd have thought in this situation you'd be better off dropping the ISO a stop and adjusting the shutter speed accordingly. I dunno; is the sharpness gain from PS enough to offset the loss in detail from using a high ISO?
08-06-2015, 04:34 PM   #5
It was an experiment to see how to use pixel shift outdoors. I will try more scenarios based on windy conditions.
08-06-2015, 04:38 PM   #6
QuoteOriginally posted by DDoram Quote
Experimenting is good.
08-06-2015, 04:51 PM   #7
If it is so windy that you really need a fast shutter to stop motion, then it's also too windy to use pixel shift. Motion between frames creates artifacts.
08-06-2015, 06:23 PM   #8
It is an experiment to see how PS works outdoors
08-06-2015, 07:48 PM   #9
If the flower is moving enough to make a 1/640" shutter speed necessary, it is moving too much to yield an artifact free pixel shift image. Even if each original image is blur free, the flower will be in different positions in each [unless the photographer is lucky].
08-08-2015, 09:49 PM   #10
QuoteOriginally posted by DeadJohn Quote
QuoteOriginally posted by civiletti Quote
What they said. The total time for all four exposures is never less than 6ms + 3x the time to do the shift, so figure about 1/60s shutter open time for a set exposure of 1/640s. That is better than a longer set time, but probably not such a good thing if the noise is high.
I would be curious to see the extracted JPEG for the first exposure to compare to the PS image, though not the whole photo. A full resolution crop of a representative section is much more helpful. It also helps if the image is hosted other than at Pentax Forums. The forum software rewrites uploaded files.
dslr, iso, k-3, k3, k3ii pixel shift, pentax k-3, pixel, pixel shift iso, shift
K3II: Pixel Shift First Test DDoram Pentax K-3 168 11-24-2015 10:15 AM
K3ii pixel shift v.s studio flash amoringello Pentax K-3 1 06-26-2015 10:20 AM
Pixel Shifting Samples from Pentax on the K3II mikeodial Pentax DSLR Discussion 99 04-26-2015 05:00 PM
ISO 6400 - Usable! jmerchant Pentax K-5 5 05-04-2014 07:15 PM
Photos: K-5 at ISO 6400 AND ISO 12,800 PeterKBurian Pentax K-5 2 01-07-2011 07:01 AM
All times are GMT -7. The time now is 07:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
