09-15-2015, 12:58 PM   #16
Otis Memorial Pentaxian
QuoteOriginally posted by Azergoth Quote
I don't think so. I don't think there is a bracketing mode in Interval Shooting Mode (timelapse) and the three images are absolutely identique (copies of each other). Furthermore, the camera does only take a single frame at each time...
IIRC, I had a similar experience when assembling the video in-camera. Depending on interval, this may enhance smoothness, but also may not. You might want to consider assembling the video out-of-camera.
09-15-2015, 01:08 PM   #17
Thanks for your reply :-)
Enhance the smoothness? But... at 24fps, divided by 3 gives 8 fps... How can that be smooth at all?
09-15-2015, 03:26 PM   #18
I guess smoothness may not be the best word. Think of the case where a participating element may only be present in only one or a few contiguous frames at a time or things like leafy trees in a breeze. The duplicate frames allow the element to be perceived and in the case of the trees, allows them to appear fully leafed, if jerkily so. That being said, I consider that to be a corner case and personally think this should be user-settable with a default of one frame per exposure.
09-16-2015, 12:47 AM   #19
Yes, at the very least!
But I must be missing something, or a setting! I cannot possibly imagine the engineers at Pentax taking such a decision! And on a semi-pro camera.
I'll try other settings to test other behaviors. Maybe it tries to output a video of e certain length and multiplies each frame by a parameter (and not a constant of three).
And, by the way, has anyone checked if bracketing was available in time lapse mode (movie, not stills).
10-02-2015, 03:52 AM   #20
I've made this little vidéo to show how to "solve" (temporary) the problem. It's not very convenient, but works form me.
10-02-2015, 06:15 AM   #21
bobbotron's Avatar
I recently did a time lapse for my work with the k3. I ended up doing an interval photo mode, and then creating a mp4 using ffmpeg from the command line - this would work on mac osx or linux (or windows if you're a little stubborn). I found that this gave me the best way to control *exactly* what's going on. Here's the ffmpeg command. Unfortunately I can't post the resulting video, I'll try to do another sometime using this method and post it up here.
ffmpeg -pattern_type glob -i 'IMG*.JPG' -c:v copy timelapse-v2.mp4
10-02-2015, 11:32 AM   #22
https://youtu.be/fVqost2DQSg
Yep...the video shows the problem nicely. Cool music too.
QuoteOriginally posted by bobbotron Quote
Take full a control and, well, you get full control
It occurred to me that the time lapse "failure" is sort of a straw man failure. For sure the K-3 implementation should give the option to select the number of duplicates (if any) per frame. OTOH, the feature is not "time-lapse" video. It is "interval movie" which is left virtually undefined. While watching a crew replacing my fence last week, it occurred to me what the feature does best.
Remember Amy (DRabbit) of runaway mirror fame? She makes interval videos of project process professionally. Good examples might be fence replacement, window replacement, or simply showing the process of making/eating breakfast. The typical interval is fairly long, say every 30 seconds or maybe even a couple of minutes. In order for things to make sense when played back, you need frame duplication. The apparent intent is to show essentially show a series of fairly closely-spaced in quick succession. That is what "Interval Movie Record" does very well. What it does not do very well is smooth time-lapse.
As noted, this is not very helpful unless you are doing that sort of documentation or doing stop-motion work or want the jerky behavior for special effect. To illustrate that this approach is not totally unheard of, see this short tutorial on making stop motion video. Adding three duplicates per frame is part of the process:
How to Make Stop-Motion Video Shorts with Your Digital Camera | Photojojo
Perhaps Pentax-Ricoh will provide more flexibility in a future implementation.
10-02-2015, 11:38 AM   #23
In Windows you can simply use Windows Movie Maker (free), though perhaps with less control.
10-02-2015, 11:51 AM   #24
bobbotron's Avatar
The problem is that people would probably find all of the options a bit alarming at first. It would be nice if there were more options though - I think by default what you get out of the k3 is pretty cool, but maybe not what you were expecting.
I also wrote a python script to average each consecutive image, so you'd then create a timelapse based on a averaged photos. As suspected, this produced kind of weird results for a time lapse but could be useful.
I did each shot at 1/4 of a second, gave a good motion blur to it.
10-02-2015, 12:39 PM   #25
I know that's the method I used before having my K3. But since it's capable of producing 4k vidéos, I wanted tu use the K3: much smaller files and less processing time.
The music is...free and provided by Youtube I found it funny to use it. (So its 100% legal! can you believe this? )
About what you say for stop motion: it's totally true!! I've also made a great stop motion timelapse (or how do we call this, now ). But then, why to output a 24 fps movie instead of a 8 fps movie?
Alarming? I don't know... when you see the overwhelming number (which I love) functions of the K3, I don't think the framerate would be that difficult to understand... After all, the K3 is a "pro" body
Hah! It's funny you mention this! I tried to do the same ... in Matlab and also to make a movie where each frame was the average if X previous ones. Pretty cool
10-04-2015, 02:55 PM   #26
Tjompen1968's Avatar
I wondered what was going on with the in camera timelaps videos. Thanks for sharing.
10-06-2015, 01:31 AM   #27
QuoteOriginally posted by Tjompen1968 Quote
Oh! Thanks I thought I was the only one
01-27-2016, 04:46 AM - 1 Like   #28
Hi everyone,
Sorry to reopen this "old post". After a long discussion with Ricoh Imaging (France), they told me the could not reproduce the problem with "their cameras".
Are there people whose camera DOES NOT behave like this? It would be interesting to know.
12-16-2018, 05:01 AM   #29
sbh
sbh's Avatar
Sorry for re-opening this. I have the same issue. Does anyone have a out-of-the-box solution?
I'd consider this as a bug and try to do a bugreport.
12-16-2018, 06:34 AM   #30
QuoteOriginally posted by sbh Quote
No news. I stopped trying to figure out how to solve it when I found the K3 isn’t a good video camera. (Which is il, I’m not a good videographer &#128539
I use my phone or other compact devices to film as the quality is much better.
If you have a solution, I’d be happy to hear it, though, as a like my camera. (Even if the K3 is getting a pretty outdated model!)
dslr, framerate, k-3, k3, pentax k-3, question, timelapse
tethering question K3 slip Pentax DSLR Discussion 10 06-25-2015 01:57 PM
K-01 timelapse question bobbotron Pentax K-01 4 03-13-2015 05:34 AM
K3 firmware question MyTZuS Troubleshooting and Beginner Help 2 12-05-2014 01:17 PM
K3 Video Question mdshooting Video and Pentax HDSLRs 6 08-08-2014 07:01 AM
Timelapse Question Spideralex90 Video and Pentax HDSLRs 7 06-19-2010 01:38 AM
All times are GMT -7. The time now is 05:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
