08-12-2015, 08:38 PM   #1
K Lenses on K3... Just To Be Sure
So, my K3 is finally here... a quiet "yay!".
And for the time being, I've forbidden all family members any attempts to engage me in conversation or other random household machinations until I say otherwise.
Now, about my K lenses. I think I know the answer but:
On my K30, I had the option of shooting in Av Mode as well as M Mode using Stop Down Metering. On the K3, however, it appears that in Av Mode the aperture remains wide open at all times. I am correct on this or did I miss something?
Thanks in advance!
08-12-2015, 08:45 PM   #2
QuoteOriginally posted by strangeboy Quote
Your K-30 and K-3 work essentially the same for non-A contact lenses. The aperture remains open except in m-mode and then only with aperture ring enabled in custom menu settings.
08-12-2015, 08:46 PM   #3
Thanks in advance!
If by K lens you mean manual lens with no contacts, then yes, that's correct for the K3, but it should have been that way on the K30 also. Any manual lens K-mount lens without 'A' contacts will only stop down in (M)anual mode.
08-12-2015, 08:52 PM   #4
I'm speaking of my K 28mm f/3.5... no "M" designation.
SMC Pentax 28mm F3.5 Reviews - K Prime Lenses - Pentax Lens Reviews & Lens Database
Stop Down Metering works just fine on K3. But in Av Mode, aperture remains open. Not so on my K30. Odd.
08-12-2015, 08:57 PM   #5
Thanks in advance!
You're supposed to be in M mode on both cameras. Av is only suitable for M42 lenses.
08-12-2015, 09:02 PM   #6
It's hardly an issue, just a curiosity. And though I'm told it should not work on my K30... it does.
Thanks for the answers.
Cheers.
08-12-2015, 09:05 PM - 1 Like   #7
Some people purposely don't click the lens in all the way (mount it fully and then back out just a bit) -- in order to be able to stop down in Av mode like you can with an m42 lens (which has no mechanical aperture connection to the body at all). But if properly mounted, a fully manual bayonet K lens should never ever stop down except in M mode.
08-12-2015, 09:19 PM   #8
UGH!!!
I stand (sit) corrected.
You guys are right... I must be tired.
Thanks again and again.
08-12-2015, 10:59 PM   #9
Not a Number's Avatar
With the K3 by enabling DOF preview to optical you'll be able to use the exposure bar meter when in manual mode. Use aperture ring enabled. In M mode, activate the DOF preview and the EV meter bars should be active. Set the exposure by turning the aperture ring or the eDial for shutter speed. ISO not set to auto.
https://www.pentaxforums.com/forums/53-pentax-dslr-camera-articles/100260-man...ic-lenses.html
08-13-2015, 02:09 AM   #10
All lenses when using the aperture ring behaves the same here, including A, F and FA-lenses when using the aperture ring away from the 'A' position.
08-13-2015, 01:19 PM - 1 Like   #11
UGH!!!
Good thing! I was starting to think your K-30 is broken!
av, av mode, dslr, k lenses, k-3, k3, lenses, mode, pentax k-3
Can C-mount lenses (CCTV) be used with the K3 or the K-cameras? Ryuno Pentax K-3 9 02-22-2015 07:45 PM
Can Nikon Ai and/or non Ai lenses be adapted to work on the K mount? Vantage-Point Non-Pentax Cameras: Canon, Nikon, etc. 3 07-28-2013 08:25 PM
Just got my new K-30. What should I check to make sure is not DOA? jrcastillo Pentax K-30 & K-50 3 07-18-2013 08:05 PM
Be sure to register your Sigma lenses for free warranty extension! Edgar_in_Indy Pentax SLR Lens Discussion 2 05-15-2013 06:57 AM
Want to buy a K-x...but not sure about the lenses Pretender Troubleshooting and Beginner Help 21 11-05-2009 07:34 AM
All times are GMT -7. The time now is 12:58 PM. | See also: NikonForums.com, part of our network of photo forums!
