08-13-2015, 01:29 PM   #1
Lille Ulven's Avatar
K-3 GPS for shift-lens effect
OK...let me try to explain what I am looking for:
When using the Astrofunction together with the Pentax O-GPS unit the sensor is able to move to a certain degree to eliminate star traces caused by the rotation of the earth.
I read somewhere - of course I cannot recall where - that the same sensor shift function would be available for "manual" sensor movement, so that one would be "manually" able to move the sensor upwards and downwards if one used the GPS. And with this one would be able to "imitate" the shift-effect that else is achieved by using a tilt-shift lens, so it would enable one to get rid of the falling lines effect in architectural photography.
Now comes the catch: I have looked through the manual and I haven't found any description of how to use this shift effect.
So I wonder: is this really a feature of the K-3 or did I only dream that this was possible? And if it is possible does anyone of the wise pentaxforum members happen to know where I can find a description of how to use it (page of the manual or website)?
Yes I could google...the point is: I have no clue what keywords I should use in that search...
So any help in this would be appreciated.
Thanks in advance.
Lille Ulven
08-13-2015, 01:42 PM   #2
boriscleto's Avatar
Sensor Shift In Action: Increasing Field of View - Tutorial Videos | PentaxForums.com
First result in Google using the keywords Pentaxforums Sensor Shift
Entering Sensor Shift into the search box in the upper right corner returns the same result.
08-13-2015, 01:42 PM - 1 Like   #3
jatrax's Avatar
Try this: How to Turn Any Lens into a Shift Lens - Tutorial Videos | PentaxForums.com
and this:
But I think it is under composition adjust and does not have anything to do with GPS.
08-13-2015, 01:55 PM   #4
The composition adjustment option can be hard to locate, but it's in the live view menu:
Like others have said, it has nothing to do with the GPS and is available on most (if not all) Pentax bodies launched since 2012.
08-13-2015, 02:02 PM   #5
mikeSF's Avatar
I posted a thread with a few examples of using composition adjust to control converging verticals here: https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/275602-compositi...you-using.html
08-13-2015, 02:50 PM   #6
Thank you all!
I would never have looked for it in the Live View Menu...
So I'll most certainly check out the videos and post you kindly provided me the links for.
architecture, description, dslr, effect, falling lines, gps, gps for shift-lens, k-3, k-3 gps, k3, move, pentax k-3, sensor, shift, tilt-shift
K-3 II Pixel shift for Macro? Omestes Pentax K-3 6 06-12-2015 08:13 PM
GPS stealth tracking on Pentax K-3 ii KreiselC Pentax K-3 15 05-15-2015 08:44 PM
GPS for the K-3 BarryDarnell Pentax K-3 14 09-05-2014 11:02 AM
K-3 and O-GPS. First bug Grokh Pentax K-3 10 12-26-2013 04:52 PM
German Color Foto claims K-3 makes any lens a shift lens RKKS08 Pentax K-3 15 10-09-2013 05:56 PM
All times are GMT -7. The time now is 07:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
