08-19-2015, 08:59 AM - 1 Like   #1
MJSfoto1956's Avatar
DxO Optics Pro support for K-3 II !
it appears that DxO Optics Pro v10 now supports the Pentax K-3 II (scroll down and select Pentax, then K-3 II)
Supported cameras | www.dxo.com
Michael
---------- Post added 08-19-15 at 12:18 PM ----------
could someone with a K-3ii download the eval copy of DxO Optics Pro and validate if it supports pixel shift or not?
Thanks
Michael
08-19-2015, 09:18 AM   #2
Do they support pixel shift?
08-19-2015, 09:25 AM   #3
There is no mention on their site. Could someone with a K-3ii download the eval copy of DxO Optics Pro and validate if it supports pixel shift or not?
M
---------- Post added 08-19-15 at 12:37 PM ----------
If someone can send me (or point me to) a K-3ii pixel shifted file (preferable an image that has both with and without pixel shift ) then I'll process it in the new version and let you know if it supports pixel shift or not.
M
08-19-2015, 11:23 AM   #4
Madaboutpix's Avatar
Not just K-3 II but several new profiles for Pentax lenses too!
While we're at it: they've also made available several new lens correction profiles that they didn't use to have, notably DA10-17 Fisheye and DA 20-40 Limited, with one for the upcoming DFA70-200 (erroneously referred to as an 80-200) announced for September 2015.
If they should really include support for pixel-shift files in their K-3 II module, they would have taken some serious steps of keeping Optics Pro up-to-date for Pentax shooters.
08-19-2015, 01:17 PM   #5
unkipunki's Avatar
Still no 645z support, so some way to go to be up to date for some pentax users
08-19-2015, 01:25 PM   #6
so I downloaded two K-3ii with/without pixel shift DNG images I found on the web -- one was 31mb the other was 114mb -- and while DxO recognized both files, it is clear that it just processes the first file in the archive, not the entire stack. Alas...
Michael
08-19-2015, 01:47 PM   #7
Mikesul's Avatar
Michael,
How could you tell that noting was done with the other files? I was just playing around with it to see if it worked but I could not determine what it did to the file. With DCU5 you can actually see the files being blended but I could not tell with DXO.
08-19-2015, 05:26 PM   #8
there was no improvement in noise.
there was no improvement in perceived resolution.
nothing like the sample photos I have seen from Ricoh (which to my eye were significant).
M
08-19-2015, 05:45 PM   #9
Mikesul's Avatar
Have you tried DCU5 with the same files? The difference is very subtle sometimes.
08-19-2015, 10:32 PM   #10
No K-S2 support yet
09-04-2015, 02:36 PM   #11
sholtzma's Avatar
What advantages do you find that DXO Optics has over (or with) other image editing programs?
09-04-2015, 02:49 PM   #12
unkipunki's Avatar
QuoteOriginally posted by sholtzma Quote
Just that it is both allied to the capabilities of a lens and the camera body it is mounted to in ways that are not replicated by other imaging editing programs. It is capable of homogenising images regardless of camera, and also maximisation of any camera's abilities. I do not use it exclusively, but it provides an excellent starting point to then use in Photoshop (for example) just better than random( or even mildly educated) slider tweaking in lightroom before bringing into PS.
09-05-2015, 03:05 AM   #13
Optics Pro advantages, in my book at least:
+ Prime (included from versions 9.5 or higher), one of the most effective and detail-preserving noise reduction engines I have seen; similar approach as Tapaz DeNoise in that each image is analysed with regard to its specific noise pattern and then cleaned up accordingly (superior to Lightroom in that respect); Optics Pro is not some kind of miracle cure, but it has made me much more comfortable shooting at high ISOs (say, ISO 3200 with my K-3)
+ powerful one-touch tools/sliders for tonality and contrast adjustments: where in Lighroom I would normally manipulate various sliders (clarity, blacks, shadows, bright parts, highlights) to obtain the tonality/contrast I'm after, in Optics Pro I go for the exposure correction (which can often be left on Smart anyway), set Smart Lighting to my wishes, and am essentially done
+ Optics Pro lets me put special emphasis on sharpening the image borders and corners, thus making up for lens aberrations
+ effective one-click correction of CAs/purple fringing
It's by no means perfect, but it can be used as a plugin along with Lightroom, and it has become a part of my post workflow I wouldn't want to be without.
09-05-2015, 04:45 AM   #14
noelpolar's Avatar
QuoteOriginally posted by Madaboutpix Quote
Me to... and DXO Filmpack
dslr, dxo, dxo optics, ii, k-3, k-3 ii, k-3ii, k3, michael, optics, optics pro support, pentax, pentax k-3, pixel, shift, support for k-3
DXO optics pro support for K-3 PEF files wizofoz Digital Processing, Software, and Printing 11 02-28-2014 04:26 PM
DxO Optics Pro 9.1.2 out -- Supports K-3 DNG klkitchens Pentax K-3 4 01-15-2014 09:32 AM
DxO Optics Pro adds Tamron 70-300 f4-5.6 Pentax support rawr Digital Processing, Software, and Printing 4 07-23-2012 06:03 PM
DXO Optics Pro (finally) to support the K-x rawr Pentax News and Rumors 13 10-24-2010 02:32 PM
K-x support coming to DXO Optics Pro by early September! rawr Digital Processing, Software, and Printing 2 07-29-2010 05:31 PM
All times are GMT -7. The time now is 05:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
