08-21-2015, 02:44 AM   #1
redcat's Avatar
SOS - Pop up flash problem
Hello,
I have a problem with my pop up flash, yesterday for no reason, the screw on the pop up flash fly away during my shoot ! Did anyone have this problem before ? do you know which type of screw I have to buy to replace it ?
The screw is marked in red here.
Thanks a lot !
08-21-2015, 03:01 AM   #2
QuoteOriginally posted by redcat Quote
Hello,
There's always a reason something happens, you just don't know what it was
My guess the missing screw is identical to the one on the other lever. Take the camera to a jeweler, he might have something suitable.
08-21-2015, 04:40 AM   #3
redcat's Avatar
QuoteOriginally posted by Steve.Ledger Quote
I click the button for the pop up flash and the flash pop, the screws fly away @_@
08-21-2015, 07:40 AM   #4
aleonx3's Avatar
When was the last time you popped the flash up? Are you using the pop up flash frequently? When the flash is up, you have to be extra careful since it becomes very fragile, an accidental bump could jar it loose. The screw would be the same as in the other arm. I would try to find a matching screw somewhere, may be an old camera, lens or etc. I trip to the jeweller would be option as well as Steve.Ledger suggested. Good luck...
08-24-2015, 01:43 AM   #5
redcat's Avatar
QuoteOriginally posted by aleonx3 Quote
i use the flash frequently to control my external flash, the crews might be loosen and both screws flied away so nothing to compare !!!
I'll take a trip to jewelery to see if they have something, thanks a lot !
08-25-2015, 11:07 AM   #6
A camera repair shop may also be helpful. If your camera is still under warranty, contact Ricoh/Pentax for repair.
dslr, flash, k-3, k3, pentax k-3, pop, pop up flash, screw, sos pop
External & Pop-up flash Tighelander Flashes, Lighting, and Studio 3 07-22-2015 02:17 AM
Problem with Pop-up Flash Cucho Pentax K-5 10 12-06-2013 08:36 AM
My K-5's going to the shop—Pop-up flash problem bwDraco Pentax K-5 5 06-18-2012 07:03 AM
K20D pop-up flash doesn't pop up! ducdao Pentax DSLR Discussion 3 11-29-2011 07:57 AM
K2000 - Pop up flash will not pop up. tkindred Pentax DSLR Discussion 6 08-17-2009 08:54 AM
All times are GMT -7. The time now is 11:39 PM. | See also: NikonForums.com, part of our network of photo forums!
