09-01-2015, 07:37 AM   #1
camera reset
I tried a camera reset which I would assume puts all the settings back to the defaults listed in the manual. Interesting that after the reset a few settings remained and I'm wondering if that is normal.
For example:
Color Space remained at Adobe RGB (default is sRGB)
All Lens Corrections remained off (default is two of them on and two off)
Flicker Reduction remained at 60Hz (default is 50Hz)
Date and Time remained current but those I would not necessarily expect to reset
09-01-2015, 07:54 AM   #2
blackcloudbrew's Avatar
As most of us have never likely exercise this option, it's hard to know what to say here. Not really wanting to test it either and haven't used that option on my K10d, K20d, K100ds, K5, and K3.
09-01-2015, 07:59 AM   #3
awaldram's Avatar
I would imagine reset defaults are dependent on the cameras country code and not a generic manual.
I don't know about your other settings as as stated above am not going to test, but I did reset my American sourced k20d and British sourced K5 prior to selling
the k20d defaulted to NTSC so would imagine a USA or country with 60hz mains would default to 60hz
the K5 defaulted to PAL so would imagine a UK or country with 50hz mains would default to 50hz
09-01-2015, 09:46 AM   #4
QuoteOriginally posted by Jool Quote
For example:
The reset option in the menu doesn't completely wipe the camera settings, interestingly. For example, if you had set copyright information, that stays as well.
09-01-2015, 06:48 PM   #5
Wingincamera's Avatar
When I reset my K-5 II the copyright info was not removed, had to do that manually. There was a couple of other settings too, but I don't remember which ones.
camera, default, dslr, k-3, k3, pentax k-3, reset, settings
Shutter Count reset mars76 Pentax K-r 11 01-26-2015 06:19 PM
Please Note: The camera menu's "Reset" is NOT a factory reset tempelorg Troubleshooting and Beginner Help 0 06-30-2014 09:55 AM
Two-button reset to defaults equivalent atilla457 Pentax K-3 2 03-27-2014 06:51 PM
Automatic reset on power off RockvilleBob Pentax DSLR Discussion 3 03-27-2014 04:56 PM
Reset Settings Richard Briggs Pentax K-5 5 10-10-2013 09:58 AM
All times are GMT -7. The time now is 07:17 PM. | See also: NikonForums.com, part of our network of photo forums!
